AOD question
Discussion in 'Technical' started by maverick7072, Apr 27, 2018.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    i found a 302 and aod out of 1983-85 lincoln VII it has a aod that im interseted in but i heard the early aods arent worth having is this true,
    the engine has v-belts and throttle body plus factory tube headers ,i can get the engine and tranny for 350.00 or 100.00 for the aod i really dont need another 302 sitting around but thats a good price
    can anyone give me some knowlege of the aods thanks
  2. groberts101
    groberts101 Member
    Minneapolis, MN
    Elaborate what you mean by.. "worth having".
    Worth having for a Maverick or Comet?.. or worth having to make a quick buck for resale?
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I have heard similar stories about the early AOD, they are week compared to later units and need updates to be as good. I guess the big questions are, what have you done to the current engine power/modification wise and what are your driving habits/use of the car like? If it has a stock 302 and you cruise it for the most part I would go for it. If you are making decent power and like to use it I would probably pass and find a later transmission.
  4. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    sorry i should have been more clear i meant is it worth using for a maverick, i have have a stock 289 with intake , carb ,andheaders with 3.50 rear gears .
    so what upgrades would it need if i ever tore into the aod and rebuilt it?
  5. Krazy Comet
    The '88-up have the improvements that include a rear lube mod and I believe larger servos... Best versions were in the 3.8 Supercoups... I beat on one from a '89 S-Coupe in my T-Bird at strip for nine years and it still works... It does have a Trans-Go Shift Kit and hardened input shaft, I broke the orig first time at strip... Input shaft was only issue I had..
    Any transmission 20-30+ years old is going to be a crapshoot...
    The 5.0 AOD flexplate will be out of balance on a 289, you'll need one for 351...
  6. RMiller
    Kennewick, WA
    Well worth using in a Maverick especially with 3.50 gears. For 100 I would get it and run it. You will have to do some work to get it to fit but there is plenty of info on here.
  7. 71gold
    of all the AOD/T-5 crossmembers I've sold, 90% were for AODs in Mav/Comets...
