aod questions
Discussion in 'Transmissions' started by JD71, Aug 28, 2008.
  1. 71gold
    just don't turn the page...:D
    PFF...:yup:
  2. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    well it looks like im going with the c4 for now. when i get the money for the rear and the rebuild of the aod( yeah right) ill put it in.
    besides the throttle cable is there any different linkage?
  3. PaulS
    Going to the AOD you may need a different shifter, the throttle pressure cable is available from Lokar and others but be sure to get the grackets for the cable when you buy it. You could make them if you are good at fabricating parts. Frank sells a crossmember to put the AOD in the Maverick/Comet. With a few exceptions that is all you need in addition to a whole working AOD and fluid to fill it with - Mercon/Dexron III.
  4. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    i was actually refurring to the c4, im thinking everything will stay the same from my I6/c4 to 302/c4 but was just making sure. i think i got everything figured out for the aod now that im not going to be using it.
    I need to know the demintions for the radiator with the 302 in a 71 mav. theres a radiator show here that has them pretty cheap with lifetime warenty but they need the demintions cause they dont have the mav in the computer
    the swap is gonna be next sat and sun
  5. 71gold
    this is the best...[​IMG] New 2 core aluminum racing maverick/comet radiator
    ...Frank...
  6. PaulS
    Your kick-down rod will be different.
