AOD (yes) install...
Discussion in 'Transmissions' started by 71gold, Aug 21, 2006.
  1. 72-Maverick
    72-Maverick Member
    Republic, MO
    1972 Maverick & 1966 Mustang Coupe
    Frank, or anyone else for that matter, do the AOD's differ in the trucks from year to year. My father-in-law has a '90 Van with 302/AOD combo. He said he'd sell it to me cheap for the motor and trans. I didn't know if the combo would fit. Guess I'll have to watch this thread for results......
    Luke
  2. 71gold
    more done
    we (they) got the aod in and bolted up.(y)
    trans. lines reflared and installed(y)
    they got the ...stock floor shift linkage...bent and installed. it shifts with the detents on the shifter..(y)
    taking my ...driveshaft in and getting it shortened 1"... it will work like it is but he said 1" cut off would make him happier...(y)
    ...:bouncy: ...
  3. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    You're going to post the pics when?
  4. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    When is later? I hope your definition of later is not proportionate to my wife's idea of 5 minutes.:16suspect
  5. 71gold
    the parts/mods. for my AOD install /conversion...
    i used... the Lokar throttle cable..(BOLT ON)
    i used the stock floor shifter and rod...bent rod to fit.. (MOD)
    i used the stock trans. mount...moved it back 2".. (MOD)
    i used the... Lokar tv cable..(BOLT ON)
    i used my satock driveshaft...(bolt on)
    i used my ...starter..(BOLT ON)
    i used the...OEM-E0AZ-6375-A flexplate..(BOLT ON)
    i used the AOD sheetmetal motor plate..(BOLT ON)
    i have 6901 headers...i had my muffler guy heat the tubes on the pass. header and bend the collector to the outside about one and a half inches..(MOD) this was to clear the AOD pan.
    i used the AOD mounting bolts, they are longer than the C4..(BOLT ON)
    ...:bouncy: ...Attached Thumbnails
    [​IMG] [​IMG]
  6. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    Too Cheap To Buy Film
  7. NAFORD302
    NAFORD302 Member
    SILEX MO
  8. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    :rant2::badwords: But, you promised. :rant2: o_O:cussing:
  9. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Nevermind.:whistle:
  10. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    "one ringy-dingy, two ringy-dingy..."
  11. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I nominate this top thread of August 06. I think this is all such good info for so many,
    Thanks
    Dan
    ps the more pics the betterer
  12. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    im really starting to like the idea of AOD , i think the next mav i get it , i will put an AOD , help it to be a crusier:drive:
  13. Dave B
    Film?? can you still buy film?? :)
  14. Jamie Miles
    Alto, GA
    I've had a few
    Heck, my grandpa still has a working Polaroid camera. Don't know where the heck he finds film for that thing. :)
  15. Ryan
    Ryan Ford Addict
    Phoenix Az.
    So the stock shift lever can be rotated 180 degrees hugh? sweet. Do you have to take out the whole thing from the inside or can it be done externally? I need to get back to my swap. Car has been on jackstands for 3 weeks. Been too busy and low on money.
