AOD (yes) install...
Discussion in 'Transmissions' started by 71gold, Aug 21, 2006.
  1. Jamie Miles
    Alto, GA
    I've had a few
    Most auto transmissions I have messed with, rotating the arm is fairly easy by removeing the nut that holds it on and simply flipping it over. The have like little notches on either side.
  2. Mavaholic
    Sara Evans, Shania Twain, Lara San Giacomo, Oh wait, were talking cars, right?
  3. 71gold
    Ryan,
    the "shift lever" i am talking about here is the one on the AOD .
    the one on the "floor shifter" i removed and heated/reshaped to hook up to the trans. but yes it did come out 180 degrees from what it was stock also.(y)
    ...:bouncy: ...
  4. 71gold
    did i mention i :drive: the car yesterday :bananaman :dance: .
    i went by the shop and he wanted me to :drive: it so he could set the "tv rod".
    after a few attempts at setting it, he was not happy with the way it shifted. the hookup on the holley carb left it too sloppy....i am going to Summit today and get the Lokar tv cable and carb bracket. they have one for the holley/aod combo.(y)
    ...will keep ya'll posted as it happens...
    ...one happy camper...frank...:bouncy:
  5. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Awesome news. I will play with my shifter tomorrow and see if I can duplicate what you did. If I can get that set up to work that saves a couple hundred bucks I thought I was going to have to spend on a shifter. Then all I have to do is finish my crossmember and bend or cut my headers away from the tranny pan :banghead: :banghead:
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Frank , do you realize all of us are riding with you when you test drive it?? Glad you are payin for the gas!!!!!!!!!!!
    Dan
  7. 71gold
    ...after i got to Summit i saw that Lokar makes a throttle cable that will work on my setup also (y). i say "will" work...will know monday.
    i was told today that..stephen moore...has one on his car...maybe he will confirm this for me :huh: .
    Ryan,
    shoot me a p.m....i have an idea about your ...headers... :shhh: just don't tell anyone.:whistle:
    ...:bouncy: ...
  8. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Ooh, ooh!!! I know! I know! I'll tell it!:evilsmile
  9. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The Lokar throttle cables use a Clevis type end on the pedal side. Ford apparently used 2 type of throttle pedals in the Maverick. One uses a loop connector with a pin and the other has a ball on the end. If you have the loop type it should be easier to hook up.
    Not sure if it was a US vs Canadian build thing or what :huh:
    An adapter will need to made to fit the ball type.
  10. 71gold
    ...this cable has both :yup: ...a clevis and a ball (y)
    ....:bouncy: ...
  11. maverick1970
    Missouri
  12. 71gold
  13. maverick1970
    Missouri
    Cool, that should really show that.
  14. 71gold
    got my ... Lokar throttle cable/ carb. bracket... hooked up (y)
    got my ...Lokar tv cable...hooked up (y)
    it was late when we finished so i will go by in the morning and see if we can get the tv cable set.:yup:
    here are pics. of the mods. i did to the cross member and rebending of the shifter linkage.(y)
  15. Dan Starnes
    West Central IL
    Frank,,,you da man!!!
    Dan
