Are C4 flywheels different - 200 to 302 ???
Discussion in 'Transmissions' started by cactusgrabber, Mar 13, 2011.
  1. don graham
    Something else to throw out into the mess is that Ford changed the input shaft from a 24 to 26 spline in 1970. So without some modifications you need to match up the convertor to the year tranny also. Just an FYI.:)
  2. cactusgrabber
    cactusgrabber Member
    Tempe, Arizona
    72 Grabber
    Update: I went back and got the flex plate, block plate, and engine harmonic balancer, from the same 73' Comet that I bought the tranny and other stuff from.
    While I was at it....I got the 302's motor-and-frame engine mounts, as well as the original "Powered By Ford" valve covers.
    Thanks for all of your help Tranny crew!!!
    Paul: Yeah...agreed...I think when we originally pulled the tranny, the torque conv wasn't unbolted from the flex-plate until after we pulled the tranny, and the shaft fell out when the tranny slid off the torque Conv/shaft.
    - Roger
  3. PaulS
    All you have to do is slide it back in.
    Just be sure which end you slide in - the splines are different - one end has 24 splines and the other end is 26. The 26 end goes into the converter and the 24 spline end goes into the transmission.
