Are these transmission cooler lines correct?
Discussion in 'General Maverick/Comet' started by unseenspeed, Jul 4, 2015.
  1. unseenspeed
    unseenspeed Member
    petaluma, ca
    1971 mercury comet gt
    Hi all,
    I purchased these from getdiscbrakes.com formerly right stuff detailing.
    I got the stainless steel lines for a 1972 Maverick v8, thinking that they would work in my 1971 comet, my old lines were off of a 1972 Maverick v8 grabber. The new lines are way longer and one of them bends 180 degrees at the transmission. IMG_20150620_155209743.jpg
  2. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    If Comet set up is anything the Maverick, those don't look entirely right.
    I just went through the same issue see post http://mmb.maverick.to/threads/transmission-supply-return-lines-or-hoses-to-radiator.104468/
    I ended up going to our local pull and save and take the lines from a 1972 Ford 150 and a 1983 E350 (I wasn't sure which ones were gonna work) Turns out the 1972 F150 lines lined right up, with very minor adjustments,
    Hope this helps, best of luck
  3. unseenspeed
    unseenspeed Member
    petaluma, ca
    Thanks for the advice. I don't mind bending some lines up or getting them from a junkyard, that's where I found the other set many years ago. I just found these stainless steel lines for a decent price, $115.00 including shipping. Figured I would be saving some time.
  4. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Some c4 transmissions came with straight fittings and some came with 90 deg fittings. Not sure how it breaks down for model/year though.
  5. 71Mavrk
    71Mavrk Member
    Nevada
    Those look right to me.
    Micah
  6. alaskamaverick
    Spokane, WA
    I paid $6.00 for both sets
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
