assembly line
Discussion in 'General Maverick/Comet' started by goldnrod, Feb 5, 2016.
  1. goldnrod
    goldnrod Member
    Fredericton, NB. Canada
    72 comet gt
    Found this sreen shot from a Youtube video "100 years of the moving assembly line" as discussed on the Concours Mustang Forum. Mustang guys found it interesting that the front fenders were on prior to paint. Funny I also thought the fenders were painted off the Mavericks. Not sure what the worker is grinding on ?
    Krazy Comet and Paul Masson like this.
  2. Krazy Comet
    Dismal Swamp
    He's probably bumping a ripple, if it were at top of rear window, I'd say smoothing the joint where top and body come together...
    All Dearborn('72 & '73 only) & early Mavericks(1970) had fenders painted off the car, as those had black engine compartments... All others the engine compartment is body color.. If fenders were painted on car bolts will be painted as well, otherwise they are natural(as on my Cobra Jet)...
    Note Dearborn also built Mustang...
  3. Paul Masson
    1971 Grabber
    The black engine compartment went body colour mid-1971 Model year. Mine was built in October 1970 and has the black engine compartment. I believe it was 74+ that the fenders were ALL painted on the car.
    Krazy Comet likes this.
  4. goldnrod
    goldnrod Member
    72 comet gt
    Great that's what I needed to know because I'm restoring a Dearborn 72 Comet with black engine bay.
  5. goldnrod
    goldnrod Member
    72 comet gt
    Are they Comets or Mavericks in the assembly ?
  6. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    COMETS Naturally !!
    Cometized
    (Chip)
  7. Krazy Comet
    Dismal Swamp
    Uhhh I should have known that... Oh well now I don't have to wait till Dec to screw up a perfect year...:slap:
    My Kansas City '71 Comet GT has body color engine compartment(as does my '72)...
    The one not on line(straight ahead) looks like a Maverick...
  8. Paul Masson
    1971 Grabber
    What's the build date on your Kansas GT car? I bet it's after January 71... I also believe that the St Thomas cars were the first to switch, and Dearborn was the last.
  9. Paul Masson
    1971 Grabber
    The Mavericks start at 4:10...
  10. goldnrod
    goldnrod Member
    72 comet gt
    Paul my player is not letting me play that video. Can you do a sreen shot?
  11. Krazy Comet
    Dismal Swamp
    Yeah it's a late one, July I believe...
    Paul Masson likes this.
  12. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Yep! Probably sneaked into the COMET line and was placed on the " side " till they could find a spot for it !
    Cometized
    (Chip)
  13. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Mystery solved .. They're MAVERICKS .. The exterior end of the taillight panel has two mounting holes that are
    VERTICAL straight up and down .. The Comets are spaced with the bottom hole in about the same spot as the
    Maverick , but the upper hole is " inset" more . Dr.Bill has made this astute observation.
    Cometized
    (Chip)
  14. Krazy Comet
    Dismal Swamp
    At KC & Dearborn Mav and Comet were most likely built on same line one behind other(along with Mustang at Dearborn), no special run of one or other... Here locally before 1973, Norfolk used to build Galaxies & F-100 on same line... In '73 they switched to F-series only...
  15. Paul Masson
    1971 Grabber
    There's really more than one shot, but this one shows a green Grabber parked beside a Mustang Sprint, plus a ton of other 72 Mavericks!
