At Fontana
Discussion in 'Drag Racing' started by Bryant, Jun 5, 2010.
  1. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    OH yeah! Great job Mo! Get some sticky tires and make yourself up some home made Caltracs and you will be knocking that time down lickety split!
  2. maverickdragger
    maverickdragger GearHead
    Oneonta, AL
    1973 Maverick
    dont burn out with the street tires and itll help some. just knock the dirt with a quick spin. street tires will get slick when they get hot. thay have alot of oil that comes out from heat
  3. Bryant
    heres the mentioned spark plug. that cylinder is down 15 psi on its compression test. im going to do a leakdown test to see where the damage is.
  4. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Wow, crossing my fingers that everything is ok Bryant!
  5. Bryant
    I'm pretty sure there's some damage. I'm hopeing it's just a valve but would not be suprised if it's a piston.
  6. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    My first thought was a valve, but you're right it could be a piston, ring or ring land.
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    so did the tip of that SP break off because of detonation or did something phyisically touch it?
  8. Bryant
    either detination or that cylinder went lean and the electrode got so hot it melted down.
