Auto Krafters z bar issues
Discussion in 'Transmissions' started by Ford Freak, Nov 16, 2018.
  1. Ford Freak
    Ford Freak IG page the_marvelousmaverick -- follow me !
    United States, CALIFORNIA
    1972 maverick 2dr 200,c4 ,ac -sold. 1972 Mexican Maverick 302 4 spd - parted out , 1970 maverick v8 swap. 63 Galaxie 500 2dr sedan , 1984 VW Rabbit GTI
    Hi guys my Current engine swap , was from a 200 inline 6/ c4 combo.
    I dropped in a stroker built by Ben alameda, an a 4 speed toploader rebuilt with the road race kit, by David kee.
    I’m running an 11 inch diaphragm race clutch
    The z bar is from Auto Krafters
    Since the og one was toast
    My problem is the roller bushings that I bought from Auto Krafters
    Are very very flimsy
    Two piece with a “A looking clamp”
    I have the threaded boss on the side of the engine for a roller plastic bushing an one on the side of frame
    So far I’m pulling my hair out , trying to get it right.
    On a different thread , I got a solution for my z bar rod.
    But this is the other issue.
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  3. dyent
    dyent Member
    vancouver bc
    can you post a picture of what you have, then we might be able to figure out something for you.......
    David
  4. Ford Freak
    Yes I’ll get them uploaded tomorrow .
    Thank you guys
    I’ll
  5. Ford Freak
    Here are some photos , sorry for the delay, the holidays set me back.
    But I did get my manual pedals installed . Thank you again to the forums it really helped on that part .
    The very last one is a pic I pulled off here on the forums.
    Of the other side of the mount, mine is still mounted on the car, I’m going to have to remove , the master cylinder ; to access it .
    09C6BF7A-503C-4942-B3A5-39D628C4CD86.jpeg 691A7901-407D-41A7-A5C6-F707E7828C3B.jpeg 70D8D249-1F91-400A-A4DF-9996982D148D.jpeg 91791AF9-6B22-4E72-A234-EC37D15CDE4E.jpeg FC77BCAE-299E-431C-B7CE-C27EBA35904D.jpeg D7A33F5F-1631-489D-BDA1-0CE86F06E55F.jpeg 49F28E02-48B5-4B0F-805D-075C6439EFA7.png BF7C197F-0D9B-47A1-828F-8F2B4AD47984.png
  6. dyent
    dyent Member
    vancouver bc
    The original factory engine side mount is that "ball end" type as seen in your last picture, it uses those 2 piece bushings that wrap around the ball stud, it is secured by that "A" wire clip into 2 holes, which are located top and bottom on the Z bar. I am not sure if the Auto Krafters Z-bar has these 2 holes, as the stud that comes with it looks like ones used for early Mustangs. So long as that Auto Krafters engine side pivot stud/bushing fits nicely into the end of the Z bar, everything should be fine. Like the original, the Z bar can be separated into 2 halves, by removing the bolt to help ease installation. Be sure to lube those bushings with chassis grease, good luck!
    David
    Ford Freak likes this.
  7. Ford Freak
    Thank you, I’ll have to do some searching for the ball type then.
    Unless they make repops
  8. dyent
    dyent Member
    vancouver bc
  9. Ford Freak
  10. Ford Freak
    76D6CDF5-AE3A-4D45-A010-43165891EFCE.jpeg CEFD3AD4-A472-4D9B-AF6F-19C3E18221FE.jpeg E0CCD7EE-FB69-4947-9D60-354882CB4804.jpeg
    So this is my 2nd issue On the frame side
    The roller is a bit small
    Not sure where to look now
  11. dyent
    dyent Member
    vancouver bc
    In the 2nd picture, there is the correct larger diameter nylon bushing for our Z-bar, however that frame side bracket is for early Mustangs, which has a smaller diameter stud..........
    I'll see if I can dig out my OEM frame side bracket and take some pictures or if another member can do the same..........
    David
  12. Ford Freak
    I’ll have to see if someone on here is willing to sell one .
    I’m so close to getting this old Mav on the road :)
  13. dyent
    dyent Member
    vancouver bc
    Here is a break down on the original Ford part numbers for those bushings:
    C5AZ-7543-D Ball Stud bushing halves, 2 required
    C1AA-7543-A Frame side bracket bushing
    D0ZZ-7K530-A Rubber seal, frame side bracket
    351517S Felt Washer, ball stud
    I am sure you will find the correct frame side bracket on this forum, post an ad in the wanted section.......
    David
    Here is picture of frame side bracket and Z-bar, I installed grease fittings so it could be lubed, I believe the bracket is specific to our Mav/Comet only......... P1020002.JPG
  14. dyent
    dyent Member
    vancouver bc
    Have you located the frame side bracket?
    David
  15. William623
    Orlando
    1973 ford maverick grabber
    If you have access to a lathe or a machine shop it is quite easy to make a stud for the frame side mount and then you could use the larger bushing that you have. If you look it is just a stud cut down a bit for the ball and then A groove for the C clip.
