Auto trans shifter lever seals
Discussion in 'Transmissions' started by mojo, Oct 21, 2014.
  1. mojo
    Anyone know if Mustang 69-73 shifter lever seal will work in my 73? I need to put seals in and see if I can get the light in the floor shifter selector dial working. If not a Mustang seal - an alternative.
  2. 71gold
    I would think so if it's for a C4. be sure and check and see if your...shifter shaft...is too long...:bouncy:
    post on it somewhere.
  3. scooper77515
  4. Craig Selvey
    Are we talking about the shifter itself.....or part of the transmission?
  5. mojo
    I am talking abt the OE shift lever seals (C4)tha (helps) keep heat, cold ,n exhaust from coming in the pass compartment.
    If I remember correctly, they are felt like material w/ split down the middle.
  6. 71gold
    like a shifter boot?
  7. Krazy Comet
    The split boot on top side of shifter is more for decoration than anything else, should be same as '69-'70 Stang and maybe later... There is a plastic bushing on the bottom lever that gets loose and floppy...
  8. mojo
  9. 71gold
    that will work...:yup:
  10. mojo
    I see the bushing u are talking abt. "Shift Lever Rebuild Kit". Will order them frm CJPony when I get the lever seals. Ur correct on the mostly for decoration, and, keep dirt/debris from getting in the housing.
  11. scooper77515
    Ignore my previous post...I guess I have no idea what you guys were/are talking about...
  12. Craig Selvey
  13. mojo
    thanks for the info. did u get them from CJ Pony?
  14. Craig Selvey
    It was either from there or The Paddock when they were still in business. They are all made by the same company I think.
