B&M shift kit wont shift!?
Discussion in 'Technical' started by JonnyRebel, Jul 8, 2006.
  1. grbmaverickmo
    Aquashicola, PA
    Seen your car at the flashlight drag website pics. what did ya race and how did you do against them (win or lose)? I`m gonna make it to more when funds allow it.
  2. PaulS
    You need to get the right gasket. None of the holes in the separator plate should be blocked off or restricted. it helps a lot if the valve body is warped a little but if it is not warped then the gasket really does very little to make the transmission work better. Any seepage between the plate and valve body sections is minimal and will not interfere with the operation of the tranny. You can put one in if it makes you feel better.
    Paul
  3. JonnyRebel
    JonnyRebel Member
    Warren Pennsylvania
    1972 Maverick 4 door, 347 stroker, c4
    My stock plate and the b&m plate have a hole or two in different places, is this correct, or did I get a wrong b&m plate?
    If it is the right b&m plate, should I use a stock gasket and just drill out the gasket where the different holes are?
    thanks,
    Jon
