B&M shifter problem
Discussion in 'Transmissions' started by my70mav, Apr 1, 2011.
  1. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    I nearly put it out front with a free to good home sign on it.
  2. blugene
    I blew up the pic of the shifter handle in the manual and the angle of how the cable is pushed and pulled looks like an area that isn't the best in design..Might look at the cable in that area to see what it's trying to do when your applying pressure.
  3. 71gold
    can you use the cable mounting bracket that is in ...figure 6...:huh:
  4. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    Yep, followed directions to the letter.
  5. blugene
    You may have already come across the real problem.. As Lee and most have said ( and you also know), it needs to be straight(er).
  6. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    I will try to notch the tunnel or build a drop bracket of some sort tomorrow and see what happens.I would hate not to be able to run this thing
  7. blugene
    Looks sharp. Any other will probobly have the same issues so may as well keep at it till it does work.
  8. blugene
    You probobly already thought of it.. Might try and remove the trans support and make a clear shot to see if that does it before notching. It will be good if you do something to make it straight but it won't hurt to see..
  9. 71gold
    ...figure 6...is a differnt bracket...than the one you are using...:yup:
  10. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    Figure 6 is for a c6 trans. Figure 5 shows the c4 bracket
  11. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    I will try that before I do any cutting.
  12. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    Sorry guysno progress today got a serious case of optical rectumitus.
  13. 71gold
    I know this...my thought is...it may work without modding your car to fit the C-4 bracket.
    you seem to think the bracket you are using doesn't work in the tight tunnel...worth a try...:yup:
  14. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    The bolt spacing is different for the c6 bracket. I have some steel plate, I may make somethin
  15. blugene
    It has been awhile since I did mine. I am remembering that I had to bend my shift bracket or turn it upside down or something.. I know it is a pain but I'm sure you'll figure it out. Frank mentioned the other bracket and you say the holes are different. Can it work if you redrill ir? Maybe weld it to a plate?..
