back end, ugly???
Discussion in 'General Maverick/Comet' started by justin has a 74, Nov 6, 2008.
  1. newtoford
    newtoford Member
    New Castle Delaware
    well if the car was at stock ride hight they would fit perfectly. the dead springs are the issue
    the wheels do slightly over extend the fenders but i dont consider it an obnoxious amount, atleast not in compairson to some things we've seen on here before
  2. maverick75
    I like blackened out and bobcat taillights
  3. blugene
    Even with new springs the tire travels up and the body comes down.
    Are the lips rolled by chance? I see some small cuts that tells me that they are not, unless there is an edge or something.
  4. blugene
    Those ARE nice. (y)
  5. justin has a 74
    kentucky
    it does look nice
  6. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    I like those huge wide tires on the back.. roll the fender lips and get a helper spring or GOD FORBID I SAY THIS HERE... Put some highjacker airshocks on it :cry: Ok I am going to go hide under a rock now for mentioning airshock in the same sentence as the word Maverick:bath:
  7. blugene
    I am going wide. I have installed 4 leaf leaf springs and Motorcraft shocks. I am hoping to get away with that, and maybe rolling the lips. I took out the air shocks, never did like the ride.
  8. newtoford
    newtoford Member
    New Castle Delaware
    even rolling the lips wont help me. the tire will still hit the outter edge
  9. Rando76
    Rando76 Member
    Claremore, OK
    We all know air shocks are a bad thing on Mavericks, but I once saw a bracket built from angle iron and mounted just under the upper shock mounts. The air shocks were mounted to it instead. This eliminated the chance of ripping out the upper mount. If you're going to do air shocks, I would recommend building something like this.
  10. justin has a 74
    kentucky
    how would you go about doing a bumper tuck???
  11. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
  12. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    SHACKLES CURE TIRE RUB.
    Large back tires that stick out are HAWT.
    There are easy ways to improve a Mavericks less than appealing posterior. I would suggest a tail light/bumper swap. Larger lights and smaller bumper.The bumpers from 74 and up are hideous and appalling for both Mavericks and Comets. Small bumper should be mandatory.
    The skinny horizontal half lights that are factory don't fill the panel completely leaving large empty spaces in the metal. Bobcat tail lights are a nice swap. I have seen Mustang tail lights from the early 70s and Shelby ones that look awesome. Cougar lights also look awesome.Comet/Montego tail lights are another option. Blackout the panel is another suggestion to make it look better.
  13. justin has a 74
    kentucky
  14. blugene
  15. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    sorry....it did the other day!
    I just did what Gene did....bumper tuck on the search engine.
