Backfire, capow!
Discussion in 'Technical' started by justin has a 74, Aug 30, 2010.
  1. justin has a 74
    kentucky
    140 in cylinder 1
  2. yellow75
    Tillamook Oregon
    Okay what are the others, dont you just love getting to them plugs :).
    I just checked my compression and it was 200 across the board but my engine is a little different than yours
  3. justin has a 74
    kentucky
    Yeh, just alittle different lol, ill chekc the others and let you know in about an hour or 2
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Go Mike! awesome instructions . . .
  5. justin has a 74
    kentucky
    WELL....
    1 140-150
    2 50
    3 140-150
    4 140-150
    5 140
    6 140-150
    7 140-150
    8 140-150
    yeh...
    number 2 is getting special treatment....
  6. yellow75
    Tillamook Oregon
    Yeah I think it deserves some, sounds like an exhaust valve issue or bad rings on that clyinder, if you can put an air hose to it and put a little pressure to it and see if the pressure is escaping through the valves or going into the oil pan when the valves are closed
  7. justin has a 74
    kentucky
    Im guessing ill hear it?:D
  8. Bryant
    with the air will here it in the exhast pipe if its and exhast valve problem. if its a intake problem it will be in the carb. there will be a little in the crack case from the ring gaps but not much. take off the oil fill cap and you will hear it.
  9. yellow75
    Tillamook Oregon
    Oh you will hear it , thats for sure just where its coming from is important.
    I will put my money on it coming from the valves since it back firing and I would even further my guess that you arent going to like it
  10. Bryant
    odds are you have a valve haing open on that cylider from your backyard valve adjsutment procedure.
  11. justin has a 74
    kentucky
    Its like really loud in the pan?
    i did have 100 psi going into it which moved the cylinder down. Im going to try another cylinder to make sure.
  12. Bryant
    you have to put that cylinder on its top dead center between the compression and ignition stroke. mark on the distrbutor body where the post for the #2 cylinder is. take off the cap. turn the crank till the rotor points at your mark. now hook up the air. if the crank turns then you were not right on tdc. try again at a little bit different spot close to where the rotor points at #2. good luck
  13. justin has a 74
    kentucky
    Still getting air in the pan:banghead:
  14. Bryant
    there will be some air in the pan. it gets by the ring gaps. alot of air is bad. do a wet compression test on cylinder 2. thats where you put a little oil in the cylinder through the spark plug hole. just a spoon full is all you need. then you do the compression test. the oil will seal the rings beter and should increase the compression test. if it doesnt go up then you have valve problems. also have you checked if air is coming out of your exhast pipe or carb?
  15. justin has a 74
    kentucky
    Seems like a little is comming out of the exhaust, i had to take the header off due to i couldnt get the dang air fitting on!
