Backfire through Sniper throttle body
Discussion in 'Technical' started by MountainDrre, Mar 2, 2019.
  1. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    Car ran perfectly before changing by valve cover gaskets and disconnecting my spark plug wires to organize them. I plugged all the wires back where they should be, I tried to start the car tonight and while turning over, poof sound up and out of the Sniper throttle body. I tried to crank it a few more times, would not start, only just turn over and then poof again, but this time it fireballed. Checked all spark plug wires by disconnecting and then reconnecting. Unhooked everything from the battery let it sit then reconnected. Will not turn over, I do have fuel pressure. Might be a timing issue from what I’ve read, but not sure how the timing could be off.
    Any suggestions?
  2. Krazy Comet
    Unless dist moved, timing is not your problem.
    Are you sure firing order is correct? a 5.0 HO is different from std 302. Also plug wire order is count counter clockwise.
    McD1970 likes this.
  3. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    Yeah all that is correct, didn’t change anything. Didn’t disconnect wires from distributor when organizing.
    McD1970 likes this.
  4. McD1970
    McD1970 New Member
    Nc
    1970 Ford Maverick 6cyl 1973 Maverick Grabber 302 w/351w heads 1967 Mercury caliente 289 4v currently building 428 3x2bbl 4spd for it
    Is it possible you accidentally crossed a couple of wires?
  5. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    It is possible. I checked for this several times over the two hours of trouble shooting. Plans today are to start with new spark plugs, in case I fouled one or more early and pull the wires and route them again. I did not mention the first couple times while trying to start the poof of air/fuel sound was accompanied by a thud.
  6. bmcdaniel
    bmcdaniel Senile Member
    A "poof" through the intake is usually either a cylinder firing while an intake valve is open (wrong firing order) or lean fuel mixture (shouldn't be a problem if your injectors are working). The "thud" tells me it's probably the wrong firing order.
  7. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    10-4. I will report back later today.
  8. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    Unplugged the spark plug wires and reinstalled, fired right up. Only thing I can think of is that I didn’t have a good connection on one of them at the spark plug. Thanks for all the help guys. I really don’t like the long boot connector (pictured below), harder to know if it’s all the way down, flex. Much prefer the 90 degree elbow/shorter connection.
  9. 71gold
    good job...:thumbs2:
  10. Krazy Comet
    If firing order was correct it should have started with three or four wires laying in street.
    jasonwthompson, 71gold and mojo like this.
  11. mojo
    Firing order was the problem;-- good, partial, no connection would not cause the problem you had!
    Glad you got it resolved.
    71gold and Krazy Comet like this.
  12. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    So I attempted to take it for a drive today after the issues. It is stuttering bad unless full throttle and noticed black smoke, smelling strong of fuel out of pipes. Could this be a timing issue?
  13. groberts101
    groberts101 Member
    Minneapolis, MN
    Could be ignition related but almost sounds more like a stuck injector. Does this efi unit have LED's for operational testing?
    Have you also confirmed sufficient and consistent fuel pressure?
  14. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    I called Holley tech support. They asked me to send them a log at idle and driving around. They cited possible electrical interference when I organized the spark plug wires to hug around the valve covers.
    I don’t think the injectors have LEDs and I should probably install a fuel pressure gauge.
