Backhalf installed
Discussion in 'Technical' started by Old Guy, Dec 2, 2003.
  1. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Looking great, Dave!
    There shouldn't be any reason you couldn't plant now - unless you throw even more horsepower at it (and none of us want to do that ;) ).
    Looking forward to 'after' pics and ultimately, a video of a run or two.
    -Rick
  2. mavman
    mavman Member
    Arkansas
    Re: Wheel Tub Install...
    Sure, any help installing them would be GREATLY appreciated. I hate sheet metal work, so I'll need all the pointers anyone can give me! Feel free to Email me
    mavman687@conwaycorp.net
  3. courier11sec
    courier11sec Member
    Tucson, AZ
    slick method.
    Does that involve a 55 gallon drum and a sawzall by chance?:D
  4. Mavaholic
    Post it here. I'd like to read it.
  5. Old Guy
    Old Guy Member
    Got some pic's of the frame sub connector and the cage. Much work left to do.
      File size:
      97.1 KB
      324
  6. Old Guy
    Old Guy Member
    Connector to front sub frame.
  7. Old Guy
    Old Guy Member
    Left two 3in long stubs of the original rear frame at the rear crossmember and welded to them. also ran two pieces of square tubing from the the rear crossmember where the original bumper mounts are located and welded and bolted them to it.
  8. Old Guy
    Old Guy Member
    Dumb A me, forgot the pic.
  9. Shorty
    Shorty Member
    Lafayette, In
    Would you mind keeping us posted on the cost of doing this because when I get another Maverick I want to do exactly what you're doing. You're doing all the labor and welding yourself, right?
  10. mavman
    mavman Member
    Arkansas
    Yep, all the labor and welding is done here by ourselves. Cost, you're looking at about $1500-$3500 depending on whether you want to buy your own housing or cut/shorten your own, as well as whether you want to use chrome-moly or mild tubing, etc.
  11. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Hey Guys,
    Here is the e-mail that I sent Todd:
    Todd,
    Sorry I haven't responded sooner...I just got back in town. Went to the
    PRI
    show in Indianapolis.
    Anyway....
    I do wheel tubs like this:
    I clamp the back portion of the tub in place, just like you would
    normally
    do to take your measurements from the back of the tub to the outside of
    the
    car.
    Then I get a piece of regular corrugated cardboard that is as long as
    the
    metal that you will be using for the top of your tub. Cut it so that it
    is
    pretty wide...within 3 inches or so from the body where the tub will
    touch.
    Then go to your local Wal-Mart store or whatever you have locally and
    get
    some wooden pick-up sticks in the toy department. I like the wooden
    ones
    because they don't seem to warp as easily, and if you need more, you can
    just break one in half, and it will usually work.
    Put the cardboard on end and insert the pick-up sticks inside the
    corrugation. It will hold them perfectly! Now tape the piece in place
    and
    get a pair of needle-nose pliers and pull the sticks out until they
    touch
    the outside of the body. Once you're done, remove the piece and lay it
    on
    top of your metal piece and trace along the edges of the sticks to
    transfer
    your pattern.
    I do all of my tubs this way! It saves me a lot of time!
    Hope this helps....
  12. Old Guy
    Old Guy Member
    Excellant tip, kudo's and nanner's to you:bananaman glad to get the info, what a time saver.
  13. Mavaholic
    Is there any good books or articles out there about how to properly set up a 4 link?
  14. mavman
    mavman Member
    Arkansas
    the best chassis book ever published is called "Doorslammers" by Dave Morgan. You can get it at Jegs, Summit, Pulley Engineering, etc. Usually retails for about $30, but WELL worth it.
  15. bigblockmav
    bigblockmav Member
    Quitman, tx
    72 Grabber
    Think you might be able to throw a couple of pics of the exterior of the car on here. Do you mind giving me the specs on your rearend and tire, (such as width, height, axle width. I am curious how she looks with the tires under her. Great job by the way guys. If i could only be as good. :bananaman
