backspacing and 275 tires
Discussion in 'Technical' started by Zechs_wind, Dec 9, 2004.
  1. Mavaholic
    It wasent the tires that caused the rub, it was the 4 1/2" backspacing on the wheels. The tires fit fine with room to spare. As far as the rear, I screwed up. When I got the 9", I had the rear lengthened by 1/4" on each side. Sorry bout that.
  2. EFIMAV
    EFIMAV Member
    Davenport Iowa
    mavaholic, that makes more sense!
  3. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    Nice avatar.......Now what was the question?
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I have mocked them up on my car and asked the same question while doing it not too long ago.
    My conclusion was that 4" to 4.25" of backspace was needed.
    The tire is tight, but will go with the right rims as attested by responses to your thread and different respondents to my thread.
    IMO 7" rims with 4" B/S would be best for 275/60s.
    The same rim would also easily accomodate a 255/60.
    That is the route I am going... the 275 is only slightly wider and an inch taller, so I can lose a little width, IMO the 275 is too tall.
    My car sat with them on there a couple days and I just couldn't get used to the extreme height of the tire compared to the rest of the car and the front tires.
    Add that to the touchy fitment... and I go 255/60.
    Dave
  5. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I have 255's on a 9 inch rim, 17 inch but 255/45's are 10 inches wide. I had to roll the fender also. Very close to the leaf & the fender but fit nicely. I will have to take some pics. I had to change the wheel studs to ARP's 3 inch racing studs for the lugs.
  6. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    NO rolled edges. all stock. I have helper coil springs on the rear. they don't raise the car any, just make up for weak leaf springs.
  7. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    Sweet. I'd like to see those pics for sure.
    AC
  8. EFIMAV
    EFIMAV Member
    Davenport Iowa
    what can be tucked
    OK, so we have seen 275s on grabber71s car but they clearly will not tuck into the wheel well. I would like to know what size will actually tuck into the wheel well on say....a maverick with worn out leaf springs to give it the narrowed rear look!
  9. ratio411
    ratio411 Member
    Pensacola
    255/60s on 4" B/S 7" rim...
    275/60s on 4.25" B/S 7" rims would come very close to being completely tucked.
    Someone here has 275s on an 8" rim with alot of backspace, I downloaded the pic of his car... The tires are almost inside the wells, that is why I say a 7" rim would do it. 7" is a little narrow for the 275, but it does work. It also gives the tire a fatter appearance. Much like that psuedo-narrowed look you mention.
    Dave
  10. Grabber-1
    Grabber-1 Member
    long island ny
    71 maverick
    I used to have a 74 grabber that I put the 4 leaf JC springs on and ran 255 60 15 cragar 8" no rolled lip no rubbing worked great also transfered rear tires etc to a 69.5 again no probs but damn those springs were stiff big difference in the handling though
  11. Scotty P
    Scotty P Member
    santa rosa, ca
    Man oh man has this issue been beaten a million times. I am running 275-60-15 DR with no rubbing. Rim is 15/8.5 4.75 B/S on a '70. Roled the inner lip SLIGHTLY to accomodate. No rubbing after new leaves stopped the body roll. Scotty P
  12. Zechs_wind
    Zechs_wind Old School Ford Rules =]
    757, 434, Virginia
    1974 Ford Maverick, free 1970 Maverick that needs everything.
    Scotty are you using a Versailles rear end on your 70? I was wondering was the Versailles width a lil longer.
  13. Scotty P
    Scotty P Member
    santa rosa, ca
    No, I still have an 8" out of a ranchero I think.. Been a long time...
  14. courier11sec
    courier11sec Member
    Tucson, AZ
    snapped a couple of shots for ya' Just sold the tires so I took these just in time.
  15. EFIMAV
    EFIMAV Member
    Davenport Iowa
    they fit much better than I anticipated. I have 7 inch rims with 3 3/4 back spacing with 235s with plenty of room. Thanks for the pics, they are great
