backspacing and 275 tires
Discussion in 'Technical' started by Zechs_wind, Dec 9, 2004.
  1. Zechs_wind
    Zechs_wind Old School Ford Rules =]
    757, 434, Virginia
    1974 Ford Maverick, free 1970 Maverick that needs everything.
    Thanks for the pics Ray, I just ordered two HD leaf springs from J C Whitney and just in time to get that 10% discount :) hopefully I still have some X-mas dinero left for me.:rolleyes:
  2. Mavaholic
    There is no way a 4 3/4" back space will work on a stock rear. The rear you have must be wider.
  3. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    Great pics Ray. Ive been wanting to see some good closeups of yours for a while. I think you just convinced me to go with an 8" wheel.
    AC
  4. Scotty P
    Scotty P Member
    santa rosa, ca
    Pulled my Centerline reciet. My rear wheels are 4 7/8" BS I will measure the rear this weekend. But it is not narrowed... Scotty P
  5. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    No way...Sorry but no way...Not if it's an original Maverick rearend...
  6. Cleaver
    Cleaver Member
    MD
    Chel
    I posted a pic of my Mav on another link
    http://mmb.maverick.to/showthread.php?t=8648&highlight=cut+coils
    15x 8 with 4 inch backspace. 275/60's rear 215/70 14's front Stock width rear end (built 9" that is same width as stock rear) The rear lip is rolled almost back on itself in the center. Basically looks like Rays on the inside. I also cut the bump stops off the frame for more clearance on the inside. Rear end travel is limited by an adjustable pinion snubber. I assure you that the wheel goes up into the fenderwell a good 3 inches on launch.
    Cleaver
  7. Scotty P
    Scotty P Member
    santa rosa, ca
    TL, since mine was a 6cyl I can promise you the rear is not original. I will meausre the length and post tonight ot tmmrw. But I am driving it so I can say WAY :).. Scotty P
  8. T.L.
    T.L. Banned
    Southern Colorado
    Okay well you obviously have a wider rearend. That explains it...
  9. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    It can be doon but it will yake some work & new wheel studs. My rear wheel is 17x9 with 5 inch backspace. The front is 17x8 with 4.5 inch backspace. the front was fine for me but I could not put a 245/45 on the front like most have done. It was to wide. The back was a more trouble. The wheels studs was to short to get the lugs on tight. The rim was circles were the lugs go in was to deep in there, I had to use a deep socket in an extension. Plus the 5 inch backspace hits the leaf.
