Backspacing on 75 Maverick
Discussion in 'Technical' started by demo913, Aug 14, 2007.
  1. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    I want to install new wheels on my maverick but i do not know what my wheel spacing is.How do i determine if the rims i want will fit or not.
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Stock BS on 6" rims is 3.5".
    Most folks on this forum will say that 4" to 4.5" BS is max on aftermarket rims.
    Personally, I think different rim makers calculate BS slightly different...
    Some guys go with 4" and it barely fits, while others use 4.5" without issue.
  3. ratio411
    ratio411 Member
    Pensacola
    What are the specs for the rims you want?
    What size tires do you expect to use on those rims?
  4. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    15x7 I want to use 205/65/15. Is the spacing the same in the front as the back. Thanks.
  5. ratio411
    ratio411 Member
    Pensacola
    The BS front and rear is same stock.
    Doesn't have to be same if you don't want it.
    15x7 will fit great with 4" BS.
    205 is a little narrow for a 7" rim IMO tho.
    I use 215s on front and 245s on back with stock 6" wide rims.
    Narrow tires on wide rims look funny... but it is a personal matter of taste.
  6. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Thank you for the quick response. The information helped me out tons.
