Bad news and Good news
Discussion in 'Maverick/Comet Projects' started by fan2488, Nov 12, 2011.
  1. darren
    Wow that looks familiar. Except my car looked like that in 1984. My first V8 car. Bought it driving for 50 bucks. Should have left it alone. Ground out the bondo and lost most of the quarter. Cut it off to replace but then found a shell to build.
  2. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    After looking at all the work that needed done to the quarter panel. I figured it would be better to replace it.
  3. fan2488
    fan2488 Member
    spring,TX
    I've been working on the spoiler for a couple of days. Bought an aftermarket one from Tony off here. I made it 1" taller and changed the profile.
  4. Dave B
    Whats in all those pails?
  5. Steven Harris
    Steven Harris Member
    Each step is in the right direction - looks good.
  6. fan2488
    fan2488 Member
    spring,TX
    I do stamped contrete work. In those pails is the antique release agent, which comes in many different colors. We make concrete resemble real stone and flagstone.
  7. blugene
    I need alot of that around my houses..
  8. Dave B
    I wish you were closer, I had some done, but the guy is a flake..I need to have it cleared every year, but he won't come and do it :(
  9. fan2488
    fan2488 Member
    spring,TX
    If you have a Bobcat dealer around the sell to the general public. Or look around for a construction supply store they should have it also or be able to direct you in the right direction. There are several different kinds available. See if he will at least tell you if he used acrillic or solvent based sealer one cant be used over the other.
  10. blugene
    Not trying to get off track.. I seen some stuff at Sherwin Williams. Is their stuff any good?
  11. fan2488
    fan2488 Member
    spring,TX
    Gene Im not sure about there sealers, I have never used it. Check and make sure its for outdoors or has uv protection. It will turn yellow pretty quick if it doesnt.
  12. fan2488
    fan2488 Member
    spring,TX
    I thought i had a rust free door. I was wrong, had to put a piece about 2 1/2 " x 10" in the front. A 3 1/2 x 3 1/2 triangle piece in the rear corner........... Trying to decide if I want to shave the door handles or not, wanting to do something different with them.
  13. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Could you pm me the color code/break down. Brands used etc. Also how many coats of clear did you do? I'm digging the color!!
  14. fan2488
    fan2488 Member
    spring,TX
    Test fitted the Quarter panel Scott and I went and picked up on Saturday from Rick Brooks. Still have alot more triming to do but pleased with how its coming along.
  15. mercgt73
    Looking good! It's a lot of work, but it will be worth it when it comes time to paint.
