Bad rings or something else?
Discussion in 'General Maverick/Comet' started by Red 5, Mar 11, 2021.
  1. Red 5
    Red 5 Member
    1977 Mercury Comet 4.1L Inline six
    So I've been having some trouble with rough idle, and some difficulty starting, but no sign that I was burning much oil. No blue or white clouds coming out of the exhaust. In the process of pulling the spark plugs I noticed that they all had carbon fowling (I've had some difficulty with my carburetor recently) but there were no signs of oil fowling. I did a compression test and cylinder 1 was low, like 125 while the others were 150-160. (I just did a dry test, I didn't do a compression test with oil because my symptoms didn't seem to fit with a bad piston ring) Got a leak down tester and did a leak down test on 1 (engine is cold, and hasn't been started for a couple days) no bubbles in the coolant, no air coming out of the carb, no air going down the exhaust I could hear but I had moderate leaking, could hear a little air when I pulled the oil cap, but could really hear when I pulled the dipstick. My guess is a bad piston ring, but I'm a little surprised that I didn't see any oil fowling, or really any smoke when I run the car. My acceleration was good too.
    Am I looking at bad piston rings, or is it something else I'm missing?
  2. 71gold
    how many miles on engine and has it set for any length of time?
  3. Krazy Comet
    Dismal Swamp
    Sounds to me this could easily turn into the Granada a friend bought with disassembled 250 in trunk. Was told motor was bad, wouldn't run over 25 mph. No obvious problems but since he knew someone with a good 250, bought that. Replacement engine did not have a carburetor, used the original Granada carb. On first test drive, found it would not run over 25 mph.
  4. yellow75
    Tillamook Oregon
    Sounds like a bad ring to me, just starting to go bad . Why else would you hear it with dipstick pulled, did you try it on any other cylinders to see if you could hear it . Where was the piston in the hole when you tried the test ?
    Hotrock and Red 5 like this.
  5. Red 5
    Red 5 Member
    The engine has at least 70,000 miles, when I bought the car the odometer read 45K but I don't know if the odometer rolled over, or if actually had 45K miles. Car was in a bit of a rough condition so I suspected it was closer to 145K, but I really don't know. Car has sat for maybe a couple months at most, I parked it because I had to do interior work (replace the seatbelt webbing, replace the carpet, deal with floor pan rust, and replace the insulation) but I ran it multiple times while it was down. Most recently I drove it a couple days before the compression test, and ran it the day before or the day of the compression test, but about a little over a week before I was able to do the leak down test. I The engine problems existed before I parked it, just didn't get around to the leak down and compression test till recently.
  6. Red 5
    Red 5 Member
    I did the leak down only on cylinder 1 and with it at top dead center (hooked the leak down tester hose up and turned the engine over by hand with a latex glove secured to the end of the hose [didn't have a balloon available] and when the glove inflated I removed the leak down tester's hose, and put a screw driver in the hole [the piston was already near TDC] and rand rotated the engine until the screw driver stopped moving out of the spark plug hole). I had done compression tests on all 6 cylinders and got 125, 145, 160, 155, 150, 155. The rest of the cylinders were within 15psi of each other (10%), so I focused on the odd man out.
    yellow75 likes this.
  7. yellow75
    Tillamook Oregon
    If it were me doing it I would also do it with the piston at bottom just to see if it gets worse or better just out of curiosity , does not look like you have a blown head gasket.
    Red 5 likes this.
  8. Craig Selvey
    Is the car using any oil?
