Ball Joints...
Discussion in 'Technical' started by TeeEl, Apr 22, 2026 at 5:30 PM.
  1. TeeEl
    TeeEl Senior Member
    Colorado
    'Just installed my new lower control arm/ball joint assemblies from OpenTracker.
    When I went to grease the passenger side lower ball joint, I expected the rubber boot to puff up as it filled with grease, but instead the grease started squeazing out of the bottom (edges of the plate that is rivited to the control arm). I haven't greased the driver side yet.
    Is this normal?...
  2. krelboyne
    krelboyne Remember
    Salem, Oregon
    Normal if they were pre-greased from the factory. They should not be over filled with grease.
  3. TeeEl
    TeeEl Senior Member
    Colorado
    I have no idea if they were pre-greased. Is that typical?...
