batteries and covers
Discussion in 'Technical' started by 73curtis, Mar 5, 2015.
  1. 73curtis
    73curtis Member
    ohio
    I can see the screen shot
  2. Acornridgeman
    Wisconsin
    Interesting - I'll have Stefan take a look at it as it is just pictures posted from other threads here at the forum ................. :huh:
  3. Stefan
    Montreal, QC
    Im not sure what happened there. I could see the picture if edited the post, but would not see once I re-saved the post. i "fixed" the issue by taking a screen shot and pasting a new image.
  4. 73curtis
    73curtis Member
    ohio
    do you need battery post extenders if you use the cover?
  5. Acornridgeman
    Wisconsin
    No - just make sure you buy a flat top battery
  6. 73curtis
    73curtis Member
    ohio
    exide makes a black flat top 3 year , the real battery only has a 90 day warranty, I'm going with the cover (drake)and exide battery, just was wondering if the posts would be long enough, didn't know how thick the plastic would be, thanks
  7. Craig Selvey
    Flat top, NO MAINTENANACE battery.
  8. 73curtis
    73curtis Member
    ohio
    how is your negative battery cable routed, where on the engine do you have it bolted too
  9. 73curtis
    73curtis Member
    ohio
    are you running any body grounds off the negative battery terminal ?
  10. Acornridgeman
    Wisconsin
    The stock negative cables runs over to the inner fender, under an L shaped bracket that secures the battery hold down to the inner fender, then over to the voltage regulator where a ground tab mounts to one of the VR mounting bolts. From there the cables goes down and bolts to the engine block. If you look at this picture of a cable set, you will see the negative with that center mounting tab. Look at that picture above with the cover on and you will see the route of the cable off the battery. Hope this helps! :)
  11. Acornridgeman
    Wisconsin
    Here is that one picture again - the one having red X trouble
  12. 73curtis
    73curtis Member
    ohio
    still have red x , does the negative cable ground by the vr and then a seperate cable to the block?
  13. Acornridgeman
    Wisconsin
    I'm uploading the picture fresh here - you should see it now
    Paul Masson likes this.
  14. Acornridgeman
    Wisconsin
    It is a 1 piece cable with a tab in the center of it - take a look at that picture of the cable set again - it is a 3 piece set. There is a negative, a positive, and the starter cable
  15. 73curtis
    73curtis Member
    ohio
    so the neg goes from the battery to the block ? does it separate at any point , thanks for the picture.
