batteries and covers
Discussion in 'Technical' started by 73curtis, Mar 5, 2015.
  1. 73curtis
    73curtis Member
    ohio
    thank you I missed your last reply
  2. 73curtis
    73curtis Member
    ohio
    I get it now, one more question, do you run a body ground?
  3. rthomas771
    Here is a better...but uglier...pic of the ground cable without much other stuff in the way to see the body ground.
  4. 73curtis
    73curtis Member
    ohio
    do you cut back the insulation and ground the body with the bolt ? is that how it would be factory
  5. mercgt73
    Curtis, the ground tab is crimped on the cable from the factory. That is the body ground.
  6. 73curtis
    73curtis Member
    ohio
    is melvins a good place to get the correct battery cables? the picture on melvins site the neg end looks different has anyone bought them for a 6 cyl
  7. 73curtis
    73curtis Member
    ohio
    l
  8. 73curtis
    73curtis Member
    ohio
    the negative one at melvins doesn't appear to have that tab on it for the 6 cyl , but the 8 cyl set shows it , I will have to call them , unless some one knows
  9. 73curtis
    73curtis Member
    ohio
    thanks I didn't notice that
  10. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I got my cover from NPD. Don't recall brand.
    Wires were from a 71 mustang. [​IMG]
    73curtis likes this.
  11. 73curtis
    73curtis Member
    ohio
    thank you!
  12. Craig Selvey
    Pretty sure you got a Scott Drake because I got it because you did. :D
  13. 73curtis
    73curtis Member
    ohio
    where did you find your radiator hoses,they look good.
  14. Acornridgeman
    Wisconsin
    They are Mustang hoses from Kevin Marti - he sells them direct at his Marti Auto Works web site or through the major parts houses for Mustang parts.
  15. groberts101
    groberts101 Member
    Minneapolis, MN
    Hi Craig.. sorry to jump in here on a tangent.. but quick question about this pic. Are those the RHS heads we were discussing in my thread about header fitment?
