Battery draw when car is off
Discussion in 'Technical' started by jg09, Nov 17, 2013.
  1. jg09
    jg09 Jon G.
    Everson, WA
    Daily driven 1973 Ford Maverick
    So the only issue with the entire system seems to be the alternator light, itself. The car runs and starts just fine. It'll run off just the alternator with no problem, ether
  2. Krazy Comet
    Pulling a battery cable while engine is running is a good way to damage the alternator...
    The alt light is controlled by the regulator, which can cause a current draw if it has a stuck contact...
  3. jg09
    jg09 Jon G.
    Everson, WA
    I swapped the old mechanical regulator for a solid state electronic one. Would it still do that?
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    yep.. easy trick to avoid that is to just momentarily pull the negative cable and set it right back in place quickly enough to tell if the engine will die.
    NEVER let it run like that for more than a quick second.. and I'd surely never try it on anything with an ECU running the show. Bad news for bonzo on anything newer.
    best bet is to learn how to use a multimeter to test these things.
