battery in trunk relocation question
Discussion in 'Technical' started by maverick7072, May 27, 2023.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    i want to relocate my battery to the rear truck. been llooking on line at different cables ! how much hot cable do i need to run from truck back up to solenoid i was thinking no more than 15 ft ?
  2. TeeEl
    TeeEl Senior Member
    Colorado
    What kind of truck?...
    DualPort and Krazy Comet like this.
  3. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Did you mean to say TRUNK ??
  4. Powerband
    Powerband Member
    NY's \H/
    .. relocating Batt to trunk has a few options, a safety disconnect is an option and required to run NHRA sanctioned events.
    pull the + Terminal off a typical Ford and the engine will continue to run on Alternator power.
    NHRA track rules require a disconnect on the rear of vehicle for safety, Ford charging system allows the car to run with battery disconnected and needs a (big) two-pole switch to disconnect battery and another to switch the Field Coil of the alternator to kill the engine. Ran wires thru flexible conduit to eng. compartment from trunk.
    hav e fun
    '61 Comet is NHRA legal
    [​IMG] . [​IMG] . [​IMG] . [​IMG] . [​IMG]
    464925 likes this.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    IIRC, I picked up about 20 ft of 1/0 welding cable. After running it up front and a short 2 - 3 ft ground, there was about 3 ft left over.
  6. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    thanks jason thats the answer i was looking for !thanks to you also powerband i will look into that as well, wanna do this the right way
  7. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    jason can u go into detail how and where u ran your battery cable .
  8. Acornridgeman
    Wisconsin
    I fixed the title for you
  9. jasonwthompson
    Carrollton TX
    My installation is basic, not NHRA like Powerbands. I used a 67 - 70 Mustang battery tray, welding cable, 200 amp breaker, nylon p-clamps, split nylon wire loom, rubber grommets, and bulkhead pass through. The negative goes through the trunk floor to the frame below. The positive runs to a 200 amp breaker. From the breaker it follows the wheel well around to the channel under the door sill plate.
    It exits into the front wheel well and runs along the frame to a bulkhead pass through in front of the shock tower, where it connects to the starter solenoid.
    Cover the cable with the wire loom to protect from scuffing/abrasions, secure along the way with p-clamps and use grommets or bulkhead connector when passing through metal.
    464925 likes this.
  10. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    I used the stock Maverick battery tray from my '75 and it worked great in the rear. I routed similar to Jason. My cable came out near the outside of the fender, so I routed it across the wheel well to the frame and covered this area with a plate to protect from a shredded tire.
    464925 likes this.
  11. 71Mavrk
    71Mavrk Member
    Nevada
    I did mine very similar to Jason. Pictures in my build.
    Micah
  12. rachjake
    rachjake Member Supporting Member
    Pace, FL
    1975 Maverick
    Jason, do you have any additional pictures and advise on your battery in trunk installation?
    I am very interested.
    Thanks
  13. jasonwthompson
    Carrollton TX
    Mine is basic and not as professional as some of the others. The cable exits the channel under the sill plate into the area behind the kick panel. I removed the splash shield from the wheel well. Made a hole with a grommet for the cable to pass through to the area behind the splash shield. The cable makes a left turn from behind the splash shield into a trough over to the frame rail where it makes a downward sloping right turn to the bottom of the rail. It follows the rail under the A-arm and then slopes upward to an existing hole where I installed the bulkhead pass through. Secure it with nylon p-clamps along the way so that it will not move and chafe, put the splash shield back on. It has been that way a few years and we have not had any problems starting, charging, or otherwise. I HIGHLY recommend welding cable. It can carry high current and is easy to route.
  14. Powerband
    Powerband Member
    NY's \H/
