Battery tray needed or not?
Discussion in 'Technical' started by AppMaverick, May 21, 2013.
  1. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    u think I have to do something that nice for the inside of a battery box? Maybe I can just use some por15.... need to get some for my floor pans anyway
  2. jrgallier
    jrgallier Member
    1977 ford maverick
    How did you add the shock to your trunk lid?? I would like to do the same!
  3. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    I'm planning to relocate the battery to the trunk as well. It's a red optima, will I have a problem with building gases in the trunk?:hmmm:
  4. AquaInferno
    AquaInferno Member
    Orlando
    1974 Maverick
    What's the benefits of mounting the battery in the trunk
  5. dyent
    dyent Member
    vancouver bc
    better weight distribution, read somewhere you would gain a couple of points weight bias towards the rear, again mostly for extremes of road racing, where ideally would be 50/50 front/rear weight ratio.........plus it cleans up the engine compartment!
    David
    SlotlessMan likes this.
  6. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Who has a battery tray for sale? :)
  7. 71gold
    get one for a mustang and put your Mav. tray mounting bracket on it...:thumbs2:
  8. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    That would work great if I had a mounting bracket!
  9. 71Mavrk
    71Mavrk Member
    Nevada
    I used the original tray with some modifications:
    Mciah
  10. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    depends on if you are drag racing or not if not drag racing why put it in the trunk?
  11. 71Mavrk
    71Mavrk Member
    Nevada
    For me, EFI pretty much requires it.
    Getting rid 50 pounds hanging out in front of one tire does help handling. So does equalizing the weight distribution on either side of the trunk.
    Micah
  12. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    most people put them in the trunk over the right rear tire to help traction in drag racing ''back in the day''if you don't need an edge racing why bother?:coco:
  13. Wizz
    Wizz Member
    Oakland,ca
    1977 maverick
    Did you remove the bar to use the gas shock or are using them both together. and if you did remove it can you tell me how
  14. 71gold
    did not remove the bar, mine I just set it on it's weakest setting.
    my situation was the trunk lid would cock up a little with any tension on the spring.
    later I found the trunk battery mounting good for my electric fuel pump. I ran the switched on pump wire to the trunk to a 30 amp relay, then short wires to the pump and battery...(E-pumps love 12+ voltage)
