Best Fitting/Performing headers for 72 302 maverick ?
Discussion in 'Technical' started by 72maverick302, Aug 31, 2004.
  1. courier11sec
    courier11sec Member
    Tucson, AZ
    I also haven't had any trouble with burning plug wires. Easiest header install I've ever done too. the pitman arm thing is weird, but pretty minor.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    One nice thing about the 6901's is the thick flanges. Haven't had a header leak problem like I did with the Blackjack's. I will have to look to see how close my pitman arm get's to them. That does seem strange.
  3. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    My car has 6901`s with Victor Jr. heads and Accel 300+ wires (also ran them with 65 289 heads) NO problems of ANY kind. :)
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    F.Y.I. these are 1-5/8" tubes. Nothing wrong with that (at all).
    The Hooker 6208-1's are 1-3/4" tubes (and a b*%$h to install).
  5. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    ROush 200 heads
    Elite headmans
    fit perfect
    Still battle the plug wires......:mad:
    But thats not the headers fault.
  6. 72maverick302
    72maverick302 Member
    How much power would you think I would get from switching to these headers and 2 1/2 exhaust ? I would guess mabye 10-30 horsepower ?
  7. Rick Book
    Rick Book Member
    Thailand
    Without knowing your other mods, I'd say the lower end of the range (12-15).
    Obviously, the more mods you have (intake, cam, heads, etc) the more you'll realize.
    What are you mods again (I'm too lazy to search)?
  8. 72maverick302
    Well it looks like your too lazy to look under my threads lol....
    Easy mistake :slap:
    edelbrock performer intake,cam,carb, rebuilt 302 9:5.1 compression
  9. danford1
    danford1 Member
    White Lake, Michigan
    Do the 6901's work with power steering and column shift c4?
    let me know ASAP. My brother has thre cash and is looking for the best deal around.
    Danford1
  10. don graham
    6901's say will not work with colomn shift and power steering. :)
  11. danford1
    danford1 Member
    What headers will work with power steering and a column shift?
    What headers will work with power steering and a column shift? (71 Comet with 302, C4, PS PB)
    Danford1
  12. Philgrau86
    Philgrau86 Member
    Shephardsville,ky
    Hello everyone! Great threads on this topic. I'm looking to get a set of the Hooker 6901's recommended, but before I ordered them, just wanted to check, when you all installed them, did you have to squeeze any of the tubes to get them to fit? Also, in assuming these are long tubes? I'm looking at the ceramic and putting them in a 71 302 Grabber with an automatic transmission.
  13. Fastkarz
    Fastkarz Member
    Northern NJ
    1972 Maverick Grabber 347/AOD/4.11
    Hooker headers but I had a horrible bump steer problem due to the factory power steering and the aftermarket drop bracket to clear the headers.
    See thread http://mmb.maverick.to/threads/headers-cause-bumpsteer-help.78980/
    Now the way I fixed this was I yanked out the Ford factory p/s and installed a borgenson P/S conversion box. That eliminated the hydraulic ram and drop bracket and the headers cleared the new manual steering linkage fine. Bump steer is GONE. I didn't use the Borgenson ball socket adapter to run the p/s steering linkage. With manual steering linkage the steering is tight.
    Philgrau86 likes this.
  14. Philgrau86
    Philgrau86 Member
    Shephardsville,ky
  15. Philgrau86
    Philgrau86 Member
    Shephardsville,ky
    Thank you for the info! I'll look into this option with mine.
