Best gear ratio for ford 8 inch?
Discussion in 'Technical' started by Chase Reed, Aug 17, 2014.
  1. Chase Reed
    Chase Reed Member
    75 mercury comet
    I have a ford 8 inch in my 75 merc comet but it has 2.79 gears. What is the best ratio for all round crusing and gettin' of the line...
  2. Bryant
    i like 3.25 if you dont have an overdrive transmission. they give a noticeable increase off the line and you can still go 70mph on the freeway with out the motor reving to high.
    Crazy Larry and Acornridgeman like this.
  3. Acornridgeman
    Wisconsin
    :agreed: - the 3.25 would be a real wake up with the automatic transmission.
    The stock 3.00 that came with a manual transmission car would be a step up too and pretty easy to find.
  4. rthomas771
    I swapped my 2.79 to a 3.00 and it made a big difference in off-line pick up...increased mpg's too. I'm going to swap to a 3.25 now that I have a manual overdrive transmission
  5. 71gold
    what transmission and engine?
  6. spxer
    spxer Member
    Raleigh NC
    i swapped out the 2.79 8 inch for a 3.50 9 inch was like a completely different really let that small block rev
  7. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    check out the DPI Platinum Track torsen/worm gear unit
    I'd also do 3.25 max if no O/D
    mine came with 3.00 stock since mine originally had the 250i6
  8. mav1970
    3.50 is what came stock in my 72 Gran Torino Sport - nice all around gear
  9. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    3.55's if you have an 8" and an OD tranny.
