Best motor oil
Discussion in 'General Maverick/Comet' started by 171grabber, Sep 5, 2003.
  1. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    a southern boy who likes republicans? j/k ( adding gasoline to a fire now)
  2. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    I use
    I use Castrol GTX 10W-30, and a motorcraft filter(supposedly no drain-back). So far so good. In my opinion, if you change the oil every 3,000 miles, and don't drive it like you Want to blow it up, that all of the oils are about the same. BUT- that's just an opinion. Country
  3. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Words of wisdom
    Country Mav you are right on the money!
    Oil is made to work hand in hand with the filter, and as long as you change them every 3000 you are making a small investment in your car or truck.
    Does anyone know what the manufacturers recommends on changing your oil?
    The 3000 miles I think is from the oil and filter people not the car builders but I’m not sure on this.
    Oil and filters are like everything else, you get what you pay for. The better the oil or the filter the more it will cost.
    Bossmav
  4. bmcdaniel
    Pennzoil and Quaker State
    BTW, Quaker State owns Pennzoil and they're both made in the same facilities.
  5. 171grabber
    171grabber Member
    florida
    1971 ford maverick grabber
    ha so it cant be that bad
  6. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I agree with everything that Mavman427 said.
    Synthetic oil is the best, however you should have at leat 10,000 miles on your engine before using it, for proper break-in. I used to put Mobil-1 in a Nissan I had. It was only about $3.50 a quart and only required 4 quarts. Not that terribly expensive.
    As for conventional oils; oil is OIL. It ALL has to meet the same specifications. I have used nothing but Penzoil in my 183,000 mile 302 and it has no sludge buildup in it.
    The detergents and additives in oil are for the purpose of maintaining desired viscosity and reducing oil break-down due to heat and condensation.
    As for filters, I don't know what the best is, but I have always used Motorcraft FL1-A for the most part.
    If you change oil often enough, you should never have any problems, regardless of brand. How often depends on the amount and type of use the vehicle is subjected to...
  7. comet dad
    comet dad Member
    Longview, Texas
    1974 Mercury Comet
    oil change intervals
    Who has looked at thier owners manuals in the mav/comets? If I remember right, since the car is not at home now, the owners manual in the comet recommended oil change every 4000 and the filter every other oil change. If you get a chance look and see....I think that is correct...........Robert:)
  8. bmcdaniel
    Oil formulations have improved tremendously since our old cars were new. I've seen several tests lately where researchers have come to the conclusion that even "regular" oil only needs to be changed after 6,000 miles of normal service. More often if you tow, drive in extremely dusty areas, or do a lot of stop and go driving.
  9. stargazer
    stargazer Member
    Deer Park, Tx
    1970 Maverick Grabber
    Hey guys, thought I would throw my .02 cents in here, since I work for one of the major Oil CO.s (Shell, which btw owns BOTH Pennzoil and Quaker State). One of the facilities I worked at did specialty blending and packaging of motor oils. I can tell you that just about all motor oils use the same identical base stock oil, and the only diffences are the additive packages. We had a 'recipe' for each oil...and we made it for Chevron, Exxon, Mobil, Shell, Unocal (I used to run Unocal 20W50 because I could get it for free), you name it, we made some of it! We didn't handle any synthetics, so i don't know about them. I agree with what somebody else said here, just pick one and stick with it, and with frequent oil and filter changes, life will be good!
  10. 171grabber
    171grabber Member
    florida
    well said
  11. bmcdaniel
    Yeah, and Shell, which was originally a British company, is now owned by a Dutch company. Sheesh, I wonder who owns the Dutch company?
  12. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    I worked for a Mobil distributor for a while too, and I remember hearing that all the major oil brands being the same base, with additives being the difference.
    Partial synthetics are a waste of money, I have heard. Either go full synthetic, or full dino.
  13. mavman427
    mavman427 has entered the building.
    SLOtown, CA
    1971 Mav with all the trimmings....302 Auto, Custom buckets, Power Brakes, A/C, PS, Grabber hood, spoiler, and mirrors.
    Good to hear reports from guys that have heard it firsthand. While we knew regular oils were the same, it's just satisfying to hear it :).
  14. Craig Selvey
    Heck...I might as well jump in.
    I have used Valvoline Semi-Senthetic. Great results. 235K on a ford Escort and still going (just sold it). Previously put 150K on a Ford Aspire and 198K on a Ford Tempo (I bought the Tempo new). None ever burned a drop of oil. Changed oil about once a month (about every 5,000 miles.....I drive a lot).
  15. 171grabber
    171grabber Member
    florida
    just so long as you some kind of name brand oil i think your car will be ok.
