best rear gears for a daily drivin 302
Discussion in 'Technical' started by JD71, May 20, 2008.
  1. Dave B
    I have my AOD hooked to the column. You should do a search on AOD's and you'll find all the info you need, there may even be a tech write up about doing the swap...
  2. 71gold
    My AOD...3:55 rear gear...85 MPH...2200 RPM...:yup:
    I didn't have to do anything to my driveshaft...
    ( 71Gold has AOD crossmembers for sale)
    P.M. him if you need one :yup:
    Frank...:drive: ILMAOD
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    The way fuel prices are, my 2 cents would be to use 3.00 gears.
    These cars came with 2.79s or 3.00s. 2.79s $uck pretty bad.
    3.00s are liveable unless you are running a moderate to wild cam... if that's the case though, you likely aren't worried about mileage. So then 3.55s are awesome.
    If I went AOD and was concerned about mileage, then maybe 3.25s or 3.40s.:huh:
    Don't get me wrong, look at my handle...;) I like gears, but you are using words like "economy" and "mileage". So my .02 is 3.00 gears.
  4. ratio411
    ratio411 Member
    Pensacola
    WTF? You got 36" tall rear tires!?!:hmmm:
    JK ;)
  5. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    Yeah I was thinking the same thing. I certainly believe 71gold and what he says. I have a 4 speed and 3:00 gears and I honestly don't think my RPM's would be that low at that speed.
    I am running about 1800 RPM's @ 55MPH according to my tach and giving the fact that my speedo is off by 10MPH.
    If all goes well with the Powertrax locker this year I may go with some 3.25:1 or maybe even 3.55 next year.
    OH and BTW with the 4 speed and 3.00 rear, pretty much stock 302 witha mild cam and an Eldebrock 4bbl and duals I am getting right around 19MPG
  6. ratio411
    ratio411 Member
    Pensacola
    I like plenty of gear, but honestly, a wide ratio toploader with 3.00 gears and 26" tires wasn't bad at all.
    With a C4, the first gear final drive ratio is 7.2:1, IIRC...
    The WR toploader brings first gear in at 8.4:1, which isn't bad at all.
    A C4 would need 3.55 gears to have the same first gear final drive ratio.
    Then in the last gear, you still got 3.55s, while the WR toploader has 3.00s.
    If you have a 3+OD toploader from a Granada, you end up even better off!
    But that is really an economy setup IMO. The ratios are too wide for performance use, again my opinion.
    That's awesome!
  7. scooper77515
    I got right at 20 highway with my 302, Edelbrock 600, and Edelbrock Performer Plus cam, P heads, 3.80 gears and 26" tires. That was cruising highway at 65mph. But if I put my foot into it, I could burn a gallon per mile.
    Haven't figured out my current gas mileage, probably much worse with the double pumper.
  8. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    Just alittle imfo I've collected from a Tech I found: 25" tires @ 60 mph from stock 302/ 3:55 = 3101 rpm, 3:08 = 2683 rpm, 2:73 = 2385 rpm. Same setup AOD dropped 800 rpm @ 60 mph.from 355's. Speedo gear = 3 mph per tooth / standard gear is 17-19 tooth. ex. speedo says faster than accual, go smaller gear. Hope this helps somebody (it did ME!) OH! stock # on Stanless Lokar KickDown cable is KD-20C4HT Works GREAT!!!
  9. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    does anybody know what vehicle a 3.00 or so gear would be in?
  10. blugene
  11. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    someone has probably already answered this question on this tread but i cant find it, if i kept the c4 in it till i could get the proper items to get the aod in, what gears would be ok for it? right now with my I6 200 it seems to rev too high on the hwy. also what would be good for the aod with out using too much gas? what cars will i find each of these? im thinking of using the 3.00 that is probably already in my car with the aod but i dont think it will work with the 302
