Best rear shocks
Discussion in 'General Maverick/Comet' started by x72COMETx, Dec 14, 2013.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    And it's still a bad idea to this day. Hopefully, you're running minimum air pressure in them (like 20 to 25 psi). The stock upper shock mounts are not designed to handle the weight and impact that air-shocks subject them to.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    So it appears that where you get the springs makes a difference. My friend got his from J.C. Whitney. The car sat just right, but rode super stiff.
  3. 71gold
    how many miles...:huh:
  4. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    Glad you confirmed this, Craig because until there is a coil-over setup for us, this is the route I'm going.
  5. mojo
    I believe "where U get them does make a difference". I'll have to check the Espo site and see what their 4 leafs ratings are.
    My springs have a rating of just over 800lbs rating. It rode like it had 1-ton truck suspension. The car at cruising spd "40mph" and abv wud have serious bump steer affect when it went over any kind of bump that wud not effect most other vechicles.
    I had/have 70 series tires on the car inflated @ abt 24psi, the car had plenty rubber between the road and my behind and was still unsatisfactory. I can only imagine what it wud have been w/ 50series, inflated to proper pressure.
    Removing the bottom leaf and installing the KYB shocks was the best thing I have done to the suspension to date.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    By "bottom leaf", you're not talking about the short overload spring, are you?
  7. mojo
    Yes! the overload bottom leaf. Overkill for a car this light-- IMO.
  8. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
  9. 71gold
    ...street or strip car?
  10. John Holden
    John Holden Member
    NJ
  11. 7D2 Grabber
    7D2 Grabber Member
    That's the pair.
  12. John Holden
    John Holden Member
    NJ
    Oh, it says "1" in the quantity box. I didn't see the word "pair" anywhere but thanks for clearing that up!
  13. CaptainComet
    If you are on a tight budget (like my whole life, it seems ... lol) here are some other possibilities ...
    http://mmb.maverick.to/showthread.php?t=50105
    I have yet to drive the car, but I can tell you that pushing down on the rear bumper is pretty stiff and laying under the car an bench-pressing the car up is fairly easy. This is with worn out original springs, too. I want to combine some Econoline leafs with the original main. Might take a couple tries to get it right, but I think this will dial it in pretty well and help get rid of the built-in understeer tendencies.
    I run these shocks on my DD Explorer Sport, and they ride great and make it handle really well ... much more like a car than an SUV. Firm, but not uncomfortable. I have had good experience with them on a previous small SUV too.
  14. 7D2 Grabber
    7D2 Grabber Member
    Just picked mine up
  15. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    if I stay with leafs
    RideTech Q-series shocks
    http://www.ridetech.com/store/1969-77-maverick-front-smooth-body-shock-rq-series.html
    http://www.ridetech.com/store/1969-77-maverick-rear-smooth-body-shock-rq-series.html
    Adjustable
    http://www.ridetech.com/store/1969-77-maverick-front-smooth-body-shock-hq-series.html
    http://www.ridetech.com/store/1969-77-maverick-rear-smooth-body-shock-hq-series.html
    They're made by FOX with Ridetechs specs
    Fox is where its at for the moment, ridetech and Hotchkis now use them with their own specific specs for rebound and all that
