Big question
Discussion in 'Technical' started by Racer_X, Mar 23, 2011.
  1. baddad457
    It's not hard at all to get 20 with a carb in a Maverick. My 331 gets 16 MPG running at 75-80 mph on the freeway with a 3x2 carbed 331 backed by a C-4 and 3.50 rear. An HO or F4TE (this is the Explorer cam) cammed roller 5.0 topped with a high rise dual plane and a 450-600 cfm Holley and an electronic ignition will do it without problem, especially if it's backed with an overdrive transmission
  2. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    Im sure it could be done with a near stock motor with 2.79 outback
  3. injectedmav
    injectedmav Member
    Georgia
    Definitely, but to get into the 20 mpg range, you will need overdrive or to never exceed 50-55mph. Not something I can do.:biglaugh:
  4. Joe Dirt
    something to think about
    I was getting 27-28 mpg on the freeway with my EFI and AOD setup 3.80's
    and 29-30 with the EFI AOD and the turbo and 3.80's
    It all just depends on your personal preferances now im back carb (much nastier spec'd motor) and getting 10-12 with a 4 speed and 3.73's
  5. Racer_X
    North Carolina
    my usual speed driving around town (at home) dosent go any higher than 55 anyway since thats the speed limit around here unless i take the express way(i rarely do unless im in a hurry), if i take it on vacation 60-75mph out near rocky mount and up through charlotte.
  6. Mad_Cow
    Mad_Cow Member
    South Dakota
    "Madison"-1972 Maverick
    You know I have no clue about Throttle Body Injection. But Sounds/seems like it would be a good mix of both carb and electronic. Though the only experience I have of it is in my brothers Caddy... Might be something worth looking into aswell... But i'm probably really wrong.
