Billet Shock Tower Caps
Discussion in 'Technical' started by MountainDrre, Jan 8, 2019.
  1. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
  2. yellow75
    Tillamook Oregon
    I would say that they will fit but there would be a height difference on shock mounting , probably not enough to matter though. Lot prettier than stock shock towers
    I have a 64 Falcon and had three different towers for it all factory--- 64 Falcon, 66 Mustang and Maverick all three fit the bolt pattern just height differences of less than an inch
  3. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    Good deal thanks for the quick reply. They sure look nicer especially if sticking with the shock towers.
  4. rthomas771
    I never measured the Maverick cap...but the '69 Mustang cap is 1-3/4" tall.
    Mike, I notice the 60 Falcon cap is different height than the 64 Falcon also.
  5. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    Interesting. I will measure tonight unless someone beats me to it.
  6. yellow75
    Tillamook Oregon
    I should have said just go to the Just ask Jeff section on the forum. LOL I did not mean to give mis information just wanted to point out that the bolt pattern is the same
  7. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
  8. dyent
    dyent Member
    vancouver bc
    The only concern is if you have cut down/shorter coil springs (see pictures), where the shock may bottom out or over extend, then the height of the shock mounting cap can make a difference, either adding spacer between shock and cap. Ideally at rest, the shock should be ~ 1/2 extended, so equal travel on extension or compression........
    David
  9. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    In your opinion would it be an issue with adjustable coilover conversion, Viking or Varishock that utilizes factory style LCA?
  10. dyent
    dyent Member
    vancouver bc
    Contact Kyle x72COMETx, he has Viking adjustable coil overs, ask him to post picture of his shock caps, (think he just used the original caps with the Viking system), might give you a better idea of what his looks like and if any "issues"........
    David
  11. x72COMETx
    x72COMETx Member
    Vallejo CA
    Not the best picture (will get some better ones tomorrow) but you can get an idea of how the Vikings look with stock upper mounts. I am actually interested in picking up a set of this billet mounts as well
  12. MountainDrre
    MountainDrre Member
    Louisiana
    1973 Ford Maverick
    The billet mounts would definitely tie in the the look. I’ll probably pull the trigger soon.
  13. x72COMETx
    x72COMETx Member
    Vallejo CA
    Here is what the billet shock mounts look like, Please excuse the messy engine bay
  14. groberts101
    groberts101 Member
    Minneapolis, MN
    It's so frustrating that most aftermarket parts, even the aluminum stuff, are heavier than the original steel pieces they replace. Oh well, I guess all the power in the world is useless if these cars are twisting and pretzeling on the road or track while you're trying to lay it all down.
  15. x72COMETx
    x72COMETx Member
    Vallejo CA
    To be honest, even though the aluminum peices are thicker and have more material to them, they are actually lighter then the originals
