my interior is satin black now but when i first sprayed it i used different brands and the colors are a little off can really notice it until you really look but i know, so my question is what is the best brand paint and name of the color to use and will match the metal and vinyl? ive herd SEM is pretty good
SEM is what I used on the interior of my cars. IIRC the color was called Landau Black. Worked really well.
I use SEM Landau Black also, make sure you use their "no sand adhesion promoter" if you want it to not scratch off. I wiped my down with wax & grease remover then scrubbed with soap and water and dried up the water. clean clean clean, not even water residue. Spray with several light coats, makes for a nicer end result. You will like what you see.
