Block Casting C8OE-6015A Ford 302
Discussion in 'General Maverick/Comet' started by alaskamaverick, Jul 13, 2015.
  1. 71Mavrk
    71Mavrk Member
    Nevada
    Agree. Unless someone had an originality or other requirement, most people would want a roller block.
    I'm looking for a '70's block because Nevada says smog is based upon the year of the block not the car. I have not yet tried to see if my red Maverick with an '89 block will make it past the inspector. I'm hoping they are not that bright. I want to avoid this potential issue with the current project.
    Micah
  2. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    Take a small die grinder and make the 8 on your 1989 block look like a 6 most of the inspectors would never know the difference ! Unless you got a real ford guy that knows the difference in the way the New blocks are cast compared to the old ones.
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Good idea, but I need a '71 and earlier block to avoid EGR. The '89 motor is already in the car. No getting a grinder to it now. I found out about this too late. If I did not convert to EFI, I doubt they would look twice. I want the early block for my other project.
    The issue with the 5.0 motor is the dipstick. The hole is cast into the block. If you know where to look, it is easy to tell.
    Micah
  4. Krazy Comet
    Correct as all '68 289 were built in 302 blocks, also applies to a few late '67 289...
    Around 1979/80 the boss was eliminated for manual clutch linkage stud... Of course the '85-up blocks are cast for roller cams, though not all the early ones were fully machined... Also roller blocks are roughly 10-12Lb lighter than the early blocks... Since the roller blocks have taller lifter bores, one would tend to think they lost around 15Lb out of the bottom end...
    Ronald Hopkins likes this.
  5. Mavit
    Mavit Member
    Prince george bc
    Man were did you get that fancy two piece block it looks like a Roller block!
  6. Krazy Comet
    Driver side has some cylinder gouges that can't be bored out, sooo if any one has a good left side half I'll :rofl2:
    Just a pict D/L several years back... Makes for interesting viewing...
    One of the local SCCA guys split a Ford Racing Sportsman block in the valley, didn't break in half but lost all it's oil pressure... Of course he likes to spin them 7500+, I believe he's using a aftermarket block now...
  7. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Just sleeve it, it'll be fine.
  8. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    Hey guys, just sold the block and heads for $400, thanks for the help
  9. Maverocket
    Northwest
    Looks like the price of that grill just went up! lol
  10. alaskamaverick
    Spokane, WA
    Pretty sure that negotiation was set in stone. I'll have my lawyer contact yours.
  11. bmcdaniel
    I've read that, too, but myself and others have measured 289 and 302 blocks side-by-side and the cylinders were the same length in each. My 289 was a '66.
  12. Cartco
    Cartco Member
    Lethbridge
    68 mustang
    Did you ever find out if that was a J code shelby engine?
    Tom Carter cell 403-634-7597
  13. Cartco
    Cartco Member
    Lethbridge
    68 mustang
    I am looking for the engine out of a 68 Shelby 350 vin ends 02220.
    Any ideas to try and find if it still exists?
    Production date was April 2, 1968
    J code engine do you have that by any chance?
    My cell is403-634-7597
  14. Cartco
    Cartco Member
    Lethbridge
    68 mustang
    So the stamping behind the manifold should be
    8T(last six of my VIN) for a numbers match for the 1968 Shelby 350? Correct?
  15. Cartco
    Cartco Member
    Lethbridge
    68 mustang
    Also we’re all blocks stamped T , J code engines?
    Do you know where I could buy an early 1968 J code engine if that’s the best I can do?
