block vin decoding
Discussion in 'General Maverick/Comet' started by BigDog41364, Jul 31, 2015.
  1. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    The stamped number on the back of the block behind the intake is 9A235145 anyone know what this means?
  2. Krazy Comet
    Yeah, 9 = 1969 or 1979, A is Atlanta assembly, 235145 is the consecutive unit number of original vehicle...
    In 1969 Atl was building Galaxies, Torinos & Fairlanes, dunno what they were doing in '79...
    Block casting will tell you whether it's a '69 or '79...
  3. rthomas771
    Bet I can remember Atlanta was making Cougar, LTD II, and BIG cars
  4. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    The block was cast late 68 can't remember exact cast date. It's supposed to be out of a 69 Ranchero. It looks like the numbers jive with what I was told by the seller. Also isn't there two different heads that were produced. Something about the casting having a 2V or a 4V cast on them, one being better than the other?
  5. Krazy Comet
    Atlanta built Ranchero in '69(but not '68, those came from KC)... Yes that means if you ordered a Ranchero from Los Angles, Seattle, Dearborn etc it had to be shipped cross country...
    The 4v heads were '68 models only... Ranchero never had the option, only Mustang/Cougar & the Mercury intermediates...
    Sounds like production was same as '69, full size & intermediates... I know they built some Fox T-Bird & Cougars in the early '80s, switched to Taurus when they were introduced in '86...
    BTW Atl was always a fullize plant from way back, I had a '64 Galaxie that was built there...Was a very late build and Norfolk had already shut down for change over to '65 models...
  6. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I'm assuming due to the C8 cast codes that the heads and block where cast late in 68 and machined and assembled in early 69
  7. Krazy Comet
    AFAIK all '68 & '69 blocks were C8...
    There are documented instances of blocks being cast one day, machined & assembled by the next day...
