blu's dash project
Discussion in 'Cosmetic' started by blugene, Jul 4, 2009.
  1. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    I like that Blugene.
    Are you reinstalling the factory gauge pod or fab up something better looking?
  2. blugene
    blugene Senior member
    I have seen alot of them in the dash and I have decided it's not for me. My decision is mostly cause I don't want to mess up the dash and not like it when i'm done. I also want to see how my pods will turn out...
    Factory. I will be working on that later today.
  3. blugene
    Also, I had my equalizer in that ac vent forever and I kinda like this dash that looks clean.
  4. PAINTANK
    1973 Comet 2 dr
    My dash has no vent hole yet I have A/C...I think it just hit me that you are using an older dashboard. Looks cool.
  5. blugene
    Car is a 73 and i'm using a 72 dash. I did also have a glove box and will now have a tray. I have two trays actualy. One will be used to see how the guages might fit. If I have to cut it I will.
    :hmmm: I can't seem to locate my replacement headlight switch :cry:
  6. PAINTANK
    1973 Comet 2 dr
    My Comet is a 73 and came with the shelf dash. I like it better than the glovebox version although I still complain about not having anywhere to put my paperwork. I don't smoke so I use the ashtray.
  7. blugene
    So now I discovered that the wiper switch that I bought for my 73 won't fit the dash :cry:. I wonder what else I will run into :hmmm:
    I don't know how a tray attatches so if someone could provide a pic or two, I would aprecieate it.
    I will also be offering my old dash pads soon. I'll redo them with something first. Anything is better than nothing sometimes :)
  8. PAINTANK
    1973 Comet 2 dr
    Here is the Fasten Safety Belt light in a 72 with A/C. Mine is the same, I do have the center vent unlike what I said earlier.
    I want to replace the center vents with a gauge pod.
  9. 71gold
    PICS. ON THE WAY...i called Jeff and he thinks he has them...:Handshake
  10. rthomas771
    The small bracket on the left is for a package tray...the larger is for lower dash.
  11. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I knew there had to be two different sizes.. are you sure the larger ones aren't for the tray? I tried setting a lower dash in place with the brackets I have, and there was a gap between the upper and lower dash.
  12. rthomas771
    Longer the bracket the bigger the gap. The short bracket has the place for sheetmetal screws...the long one has bolt holes
  13. blugene
    I have those. I am not sure how it all goes together. Is it that the tray goes in after the dash is in place?
    Some more pics, from today.
  14. blugene
    Do you happen to have a pic of a corner/end in the car?
  15. Mavman72
    I will go take some pics right now for you Gene.Gimme a few minutes to up load and post em and hopefully your questions will be answered.
