blu's Mav grill project
Discussion in 'Cosmetic' started by blugene, Jun 30, 2009.
  1. blugene
    blugene Senior member
    I worked on the grill a little this morning. Currently waiting on some paint to dry before I get back on it this evening.
    The center part is the hardest part. So far I havn't found a way to have it made. I had to make it by hand and it took some time. This may become optional like everything else lol.
    All the mock ups are on a thin plate. The actual plate is fairly thick. So far everyone who has seen it agrees that the weight shouldn't be a problem. It should be durable. The mesh may be the weakest part of it but we'll see. I'll have additional pics later this evening.
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    Gene,
    Just a thought here, instead of one standard blinker on each side you could put new styled lights and sockets top and bottom of the grill behind it and set up a sequential controller. so that it would be amberish flames and when the blinker runs it sequentially fires away from the center. with the brighter bulbs, they dont have to be directly in the way of your airflow but beaming from behind the metal into the open space....
  3. mav1970
    WOW:shocked:
    Don't know how I missed this thread but that's incredible, Gene :thumbs2:
  4. blugene
    Thanks for the ideas. I will reflect back to them after I get one done. I am trying to make it where I can whip one out if someone was to want one. Any lighting ideas might be up to the buyer. I am actualy trying to make the lights an add on because I see that some guys have them down under.
    Thanks.
  5. blugene
  6. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    (y) Thats sharp
  7. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    That is a cool looking grill.
  8. blugene
    I wonder if there will be a Maverick I can test fit this into at The Gathering..?
  9. blugene
    The proto type is done and waiting to see IF it will fit. Today I discovered that the angle needs a slight tweek :cry:. It is a little rough but I need to see how it is fitting before I can massage it again. And thinking about it just now, I forgot to put on the center support tabs :banghead:
    Here are a couple more pics.
  10. mavmike72
    mavmike72 Member
    louisville kentucky
    That sure is a good lookin emblem you have their...........lol
  11. blugene
    I can get you some :rofl2:
  12. mavmike72
    mavmike72 Member
    louisville kentucky
    You grill looks really good. :thumbs2:
  13. blugene
    Updates soon. :rolleyes:
