Body Buck Tags
Discussion in 'General Maverick/Comet' started by Craig Selvey, Oct 16, 2006.
  1. Acornridgeman
    Wisconsin
    Jamie's picture is right, but it is the drivers side. You can see it hanging there in front of the green arrow.
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    mine was on the passenger side towards the top
  3. Acornridgeman
    Wisconsin
    That is interesting, another great FORD inconsistency with these cars. My car was made in Dearborn, MI and was on the drivers side just like Jamie's picture.
  4. Jamie Miles
    Alto, GA
    I've had a few
    You missunderstand my post. I said if it is a Wayne, Michigan (W V.I.N.) built car, it is on the drivers side where I pointed. If it is a St. Thomas, Canada car (X V.I.N.), it is on the passenger side.
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Here's mine, St Thomas built 74, Tan inside/out, was 250 auto with air and ps
  6. Jamie Miles
    Alto, GA
    I've had a few
    Here is the tag off my brother's '73 2 door. The car is yellow with tan interior, 250/3 on the tree, 3.00 rear gear, A/C. Door tag codes: Body: 62A, Color: 6E (Med. Bright Yellow), Trim: BT (Avacado, this has to be a screw up as the car obviously had tan interior), Trans: 3 (unknown code?), Axel: 6 (3.00:1 rear), D.S.O. 12 (Buffalo, NY, and yes it's a very solid body!).
    It's kind of hard to read in the pic, so I'll post what it says below.
    The top line reads:
    0849 MV62A 12 15
    Three middle lines:
    L316890
    STD SPM BAG
    A/C 27
    Bottom line:
    6X YEL BGE
    I was unable to get the tag off my '74 Grabber. I tried to no avail, but the screw is firmly rusted into the core support, makeing it impossible to turn. I do not want to break the tag, so I will have to grind the screw down in order to remove the buck tag. I'm going to have to get the tag off regardless, since the core support will have to be replaced. The data on it is layed out diffrent then the Canada cars, and it dosen't list the colors the car was. I will get it off when I go back this weekend.
  7. Jamie Miles
    Alto, GA
    I've had a few
    You know, what I wonder, is why do some of the tags have little things stamped into them. As you can see, the tag off the '73 has two little hearts stamped out, my '69.5 has like the outline of an old Chrysler logo, the tag Craig posted has some little designs, Maple Mav's has some sideways S's or something, Ralph's has an A and some other design, Dennis' has a sideways 2 and a W, and Eddie's has an H or W and a triangle.
    Wonder why they did that? Notice not all of them have things stamped out.
  8. Craig Selvey
    Jamie....does the 1973 have a vinyl top? what about factor sport mirrors? If it does.....edit your original post. If you know the actual interior code off the door jamb...add that as well as the rest iof the data sticker codes.
  9. Jamie Miles
    Alto, GA
    I've had a few
    My bad, no it does not have a vinyl top. I "think" it may have had Sport Mirrors, I'll have to check with Earl. It currently has no mirrors, but if memory serves correctly, it has places on the passenger side for sport mirror also. The car is a non Grabber car, VIN 3X91L316890. Don't let the pics fool you, aside from the doors, the body is VERY solid with only light surface rust. Not one speck of rust on the underside of the car. The car has been converted to column shift automatic at some point in it's life. Hope this helps.
  10. spork1o1
    spork1o1 Member
    Michigan
    this is the one from my car.
  11. Jamie Miles
    Alto, GA
    I've had a few
  12. broncoisl
    broncoisl Member
    Iceland
    1974 Comet 351W
    My Comet is made in Kansas City, but I can't find the tag
    4K31T 541056
    4 – 1974
    K – Kansas city
    31 – 31 / 62B - Comet 2-door Sedan Standard or GT
    T – 6-200 - 1 bbl - 84 Horsepower
    541056 – Consecutive Unit Number
    Body 62B – Comet 2-door Sedan Standard or GT
    Color 5T – Saddle Bronze Poly (Metallic)
    Trim PU – Tan - Luxury Decor Option
    Trans W – C4 automatic
    Axle 3 – 2.79:1
    DS0 96 – Export
  13. Jamie Miles
    Alto, GA
    I've had a few
    Kansas City cars don't have buck tags.
  14. lilfarley
    lilfarley Chris Comley
    Central City, Iowa
    my 74 2 door 302 has one on the core support
  15. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Holy crap,, I just discovered this post. I gotta look at my Stallion tomorrow. Itsa faran build.
    Dan
