booster bracket
Discussion in 'Technical' started by Bud, May 20, 2017.
  1. Bud
    Bud Member
    1974 maverick 2dr
    I'm looking for the bracket that goes between the firewall and the brake booster want to put power brakes on my 74 Maverick .
  2. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    My friend has one for $40 plus shipping I will send you a PM with his number.
  3. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    you are also going to need the pedal assembly and under dash bracket
  4. Mavaholic
    And if you have a manual transmission, you can't use the stock set up.
  5. baddad457
    X 2 on this, you gotta go "whole Hog" here. You can't mix the parts between the two setups.
