Borgeson Power Steering Pump 800330
Discussion in 'General Maverick/Comet' started by rag9836, Aug 15, 2018.
  1. rag9836
    rag9836 1972 Comet, 67K
    Riverside, CA
    Comet
    Just installed the 800330 Borgeson Pump. It's on the last row of crank pulley and the pulley for the Borgeson Pump uses a smaller belt...Like alternator size.
    So I attempt to swap the pulley from the old pump to the new pump and she's no fit. The Borgeson Pump uses a 3/4" diameter shaft which is a hair too big for the old stock pulley. The new pulley literally falls on the old steering pump shaft... super loose.
    So I email Borgeson and they state the larger belt from the stock pulley should be fine on the smaller pulley of the new pump.
    Has anyone run into this?
    Thanks
  2. Krazy Comet
    At higher RPM, I doubt the large belt will stay in place.
    I've used narrower belt on wide pulley without issues.
    BKelley likes this.
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I agree, as long as the belt rides on the side without making contact in the bottom of the groove you will be fine.
  4. mojo
    I am not sure what the question means, smaller belt width , or length of the belt?
    I am using their pump and no issue other than using a slightly shorter belt.
