Bought my second Mav, but need your help
Discussion in 'General Maverick/Comet' started by madbaverick, Aug 3, 2008.
  1. madbaverick
    madbaverick Member
    broken Arrow, OK
    1973 2-door Maverick, 1977 2-door Maverick
    I have been told that works on the 170 and 200, but the 250 supposedly
    has a higher deck height. I looked at it some more and I actually think that the butterflies maybe hitting the hood. I may have to try a shorter adapter like Randy was talking about.
    Cary
  2. Rando76
    Rando76 Member
    Claremore, OK
    You can look at the one I have - it's a custom made adapter. It's not "refined", but works good.
  3. Jerryfow2
    Jerryfow2 Member
    Milltown IN
    1972 Grabber/1972 Sprint/1976 Stallion
    Rando 76,
    Can post or email me a pic or two of your set up? I am curious of the difference between yours and others on the market. Are you able to use the factory cleaner?
    Thanks
    Jerry
  4. Rando76
    Rando76 Member
    Claremore, OK
    I'll try to take some pics soon. The previous owner made this adapter. I didn't plan on using it on the car it's on, so I haven't done much with it yet. The air cleaner is some sort of hybrid assembly with a Pinto lid and a trimmed base.
    I'll post pics when I can.
  5. scrapper60
    scrapper60 MCCI Member
    Alabama
    Is that an adapter under the carb? If you don't want to cut your hood, how about going back with a stock carb?
    Very nice car BTW.
    Jerry
  6. madbaverick
    madbaverick Member
    broken Arrow, OK
    Thanks for all the compliments. The car is very nice. Alot of
    work was done to this car.Whish I could take credit for the work
    but I just bought it. If you do a search for Dalmav on the site he
    posted pics of some of the work he did. As for going back to stock
    that will probably be my short term solution, but I hear so many positive things about running this proggressive 2 barrel I am not ready to give up on it yet.
    Cary
  7. CaptainComet
    The Comet GT scoop is the same scoop used on Cougar Eliminators and a few other Fords and Mercs. It actually runs three part numbers and has three pairs of mounting lugs in the front, presumably so that it will clear hood reinforcements on the different cars that it was used on.
    There are several repops out there. Some do not have the mounting lugs in the "correct" positions, but if you are starting with an undrilled hood, it shouldn't be a problem other than interference with the ribs underneath.
  8. Rando76
    Rando76 Member
    Claremore, OK
  9. madbaverick
    madbaverick Member
    broken Arrow, OK
