brain box? whats the green wire for
Discussion in 'Technical' started by justin has a 74, Sep 23, 2009.
  1. justin has a 74
    kentucky
    the box in the engine bay that says motorcraft on it... their are several wires going to it and i have a green wire that misteriously connects from the "brain box" to the guages... what is this wire for??? do i need it (stupid question but do i actually need it...)
    what does this wire do???:huh:
    im tring to make it so the lights to the guages turn on through a switch in the dash:rolleyes:
    help please asap... it looks like its going to rain:mad::cry:
    (270 999 5508 call if you wish:Handshake)
  2. justin has a 74
    kentucky
    ok.... where should it go.... anyone at home that can check their mav???
  3. Dave B
    Brain Box? whats it look like and where is it? (Cars don't have brains....:coco:)
  4. scooper77515
    I think he is talking about the ignition module. I am not sure, mine never had it, but I have seen 5.0 mustangs and it had Motorcraft written on it.
    Does it look kinda like this?
  5. Jamie Miles
    I'm guessing you're either talking about the voltage regulator or a Duraspark box. If it's the Duraspark box, the dark green wire should go to the negative side of the coil. If it's the voltage regulator, it should be a light green wire with a red stripe, and goes to the ALT light on the cluster to warn you when your alternator stops charging.
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    where is it located? on the fender near the starter solenoid? I'm pretty sure that's the voltage regulator.
  7. justin has a 74
    kentucky
    no... thats an ignition modual (like you mentioned:D)
    the box that says motorraft on it on the passanger shocktower(y)
  8. justin has a 74
    kentucky
    so i dont need it??? is this correct:16suspect
  9. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    That would be the voltage regulator.
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    are you talking about that think under the big red wires? That's the voltage regulator for the alt isn't it? Well Bryant told me it was the hyperdrive helium atomizer but . . . :hmmm:
  11. justin has a 74
    kentucky
    yes the voltage regulator.... so do i need the green wire..........
  12. rthomas771
    I don't have a green wire...I have a light green with red stripe that goes to the charge indicator light. Mater of fact I do not recall a solid green wire anywhere.
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    So there should be 3 or 4 wires coming off (I just went over this with Bryant for my alternator upgrade, blame him if I'm wrong or just blame his anyway) . . . green with a stripe goes to the instrument cluster. If you have your ignition on, that wire should read a little less that battery terminal voltage. They are labeled apparently if you look at the little plastic tab (I couldn't find it on mine).
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I found this on the web . . .
  15. 75 Vomet
    75 Vomet Member
    Shickshinny, PA
    75 Comet GT, 03 Ranger, '11 Fusion,'13 Escape S
    found this somewhere. but i have a Chiltons also. Comes in handy.
