Brake bleeding help
Discussion in 'General Maverick/Comet' started by ford71, Apr 4, 2015.
  1. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
    I have been trying to bleed brakes today and the small reservoir keeps drawing fluid even with the front brakes? HELP
  2. maver88
    maver88 Nick Taurone
    Russellville, AR
    1972 Ford Maverick 2-door & 1996 Ford F150 4wd w/ 429ci/granny low 4spd
    You may need a proportioning valve or at least take it apart and clean/re o-ring it, was the system empty when u started?
  3. Moneymaker 1
    Panama City Florida
    Are you sure you have them hooked to the MC correctly?
  4. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
    I think your right the can you get the parts from the local parts store? Went to Napa today dear in headlights when I asked about it.
    i believe it is plumbed right
    yes it was empty
  5. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
    I have switched the lines and the front cylinder draws but not the back? Does it leak buy in the porpotioning valve?
  6. Bryant
    did you bench bleed the master cylinder?
  7. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
    Yes. Found piece oh brake fluid foil in master all fixed thank you for all the help. This site is Awesome!
