Brake drums
Discussion in 'General Maverick/Comet' started by zanti, Jan 5, 2017.
  1. zanti
    zanti Member
    Nowhere
    1975 Maverick
    Is it possible anywhere to get new brake drums for the front on my 1975 Maverick? My first guess is no, but you never know. Failing that, maybe a good source for almost new ones, that is, that have most of the original material srill on them.
    Thanks a lot to everyone for the past help I've received.
  2. Acornridgeman
    Wisconsin
  3. zanti
    zanti Member
    Nowhere
    1975 Maverick
    Hey, buddy, thanks for such a quick reply. Guess I shoulda specified mine is 4.1l 1nd 250 cubic inches. My mechanic tells me that the original specs were something like 10.060 inches diameter, if that makes sense, so I think none of those would fit. But at least it's a start. I don't know what that CENTRIC 12361016 C-TEK Standard Brake Drum-Preferred is, but there's only one anyway.
    I was thinking that maybe if I can find some used from a salvage yard, if they have close to original specs on them, then maybe I could have them turned if need be and that would give it a good long life anyway. Thoughts? Thaks again.
  4. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    The Raybestos 1660R drum referenced above has a nominal diameter of 10.00", discard diameter is 10.06" and an outer diameter of 12.38".
    It is the only 5 lug drum replacement for the front.
    Acornridgeman likes this.
  5. Acornridgeman
    Wisconsin
    The 1660R is also listed for the 250CID Maverick.
    I would not mess around finding old drums. There has to be a set of new ones someplace.
    I could check Hollander and see what crosses - but I'm sure that 1660R is the right one.
  6. BKelley
    Stone Mountain, Ga
    "72" Comet GT
    I would call Raybestos directly and ask them where you can locate 2 of the professional grade 1660R or 2 of the plus grade 1660 ....
    1-800-323-0354
