brake light switch
Discussion in 'Technical' started by JHodges, Jun 2, 2013.
  1. 71gold
    I was asking...can you feel the brakes working before the lights come on?
  2. 71gold
    does the tension from the rod applying pressure to the M/C have any bearing on the spring/light?
  3. Bryant
    its the resistance against the rod that activates the brake lights. a power brake system will have less resistance and will need a lighter spring than a manual system.
  4. 71gold
    so "fading" brakes or bad M/C could delay the activation of the lights...:huh:
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Wow, this is a long thread for just a simple brake light switch. Get a new switch = problem solved. Just get the appropriate one for power or manual.
  6. mojo
    Yes... I feel brakes B4 lites activate.
  7. 71gold
    you suggesting threads have a...post limit...:hmmm:
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Only your threads. :rofl:
    'Just saying it should have been fixed by now. ;)
  9. mojo
    Installed new switch today. U were right-on Larry! Problem solved. (y)
    Thanks. Cool temp "mid 60's today - so gud time to crawl under dash - waitin for a day like today.
    Brake lite comes on if u just barely touch the pedal. I wud/might never have known my brake lites were malfunctioning, if I had not installed the 3rd. lite.
