Brake master cylinder upgrade
Discussion in 'General Maverick/Comet' started by x72COMETx, May 7, 2017.
  1. bmcdaniel
    Had a chance to communicate with a place today that makes aftermarket master cylinders and I asked about needing a residual pressure valve for drums brakes. Seems nowadays it depends on the design of the MC. If the internal piston is shaped a certain way and retracts quickly enough it will maintain a minimum amount of pressure in the lines for the wheel cylinders to stay sealed without using a separate valve. Their MC's work this way, a separate valve is only needed if the MC is lower than the wheel cylinder. So the answer is "it depends"...
    I was looking at one of these:
    http://www.ebay.com/itm/380584877050?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
  2. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    "Bench Bleed" the master cylinder before installed?
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Yeah, bleed it before you install it on the car. The bench is optional.
  4. Krazy Comet
    I have a favorite chopping block I generally use...
    Crazy Larry likes this.
  5. x72COMETx
    x72COMETx Member
    Vallejo CA
    it looks like brake fluid is coming out of the top of the metering block were the switch connects
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You need a new pressure switch then. Should solve the problem.
  7. x72COMETx
    x72COMETx Member
    Vallejo CA
    Idiot here, so I checked my calipers on the rear and I have the passenger side caliper bleeder at the lowest point, I will flip that bracket and caliper and see if it brings the pressure up
  8. x72COMETx
    x72COMETx Member
    Vallejo CA
    Flipped the caliper and solved the problem
