brake upgrade
Discussion in 'General Maverick/Comet' started by wlchambers, May 24, 2017.
  1. wlchambers
    wlchambers Member
    Eddyville KY
    We have an 8 inch diff with 4 lug axles and 9 inch drums. The info I have accessed identifies the flange bolt pattern as a 7.25 diff. used in late 60's falcon applications. Falcon station wagons had 10 inch drums. Does anyone know the bolt patterns on these drums/axles ?
  2. Craig Selvey
    Ford 4-lug patterns for Falcons, Mustangs, Mavericks were 4 1/2".
  3. wlchambers
    wlchambers Member
    Eddyville KY
    Thanks Craig. To clarify my question I wanted to know if falcon wagons had 4 or five lug patterns . From info I have gained since it appears they were 5 lug which does'nt help our project.
  4. Krazy Comet
  5. CaptainComet
    I would bet that Falcons had 4 bolt axles if a six cylinder and 5 bolt if V8. Very common for Ford to do that. I even saw a 1970 Mustang Fastback for sale with 4 bolt wheels (6 cylinder motor) ....and the price was way too high ...
  6. wlchambers
    wlchambers Member
    Eddyville KY
    Thanks for all your replies. The problem with the odd flange bolt pattern and 4 lug axles might have to be solved at the machine shop. I will be going to the get together in Somerset KY in July so I can see first hand what others have done.
  7. Krazy Comet
    Yeah all the 170(64½) & 200 Stangs used 4 lug through 1970... The '69/'70 250 had 5 lug, and was only the 6cyl avail '71/'73...
    I believe was same for Falcon but they never had 250 as option('70½ excepted), not sure about the Wagons & Ranchero...
  8. wlchambers
    wlchambers Member
    Eddyville KY
    We'll keep working on the rear brake set up. In the mean time here's another question. Moving to the front brakes has anyone installed SSBC disc brake conversion kit A120-4 and how did it go ?
