Brakelines 70 Mav
Discussion in 'Technical' started by Dianne, Jul 26, 2013.
  1. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    I've not tried what predfan has done, but a quick google search found companies that will reproduce brake hoses. I do not know if this company is still in operation or not but worth a call should the mustang thing not work out for you.
    http://brake-hose.com/we-make-ford-brake-hoses
  2. Dianne
    Dianne Member
    Nampa, ID
    1970 Ford Maverick, 1973 Grabber, 1973 Pinto Wagon, 1978 Mustang King Cobra II, 2004 Mustang Convertible
    I'll give them a call on Monday. I can't imagine what a custom set of brake hoses would cost though.
  3. predfan2001
  4. rthomas771
  5. Dianne
    Dianne Member
    Nampa, ID
  6. predfan2001
    The big thing is would it bolt up. You could always reposition the hose bracket and adjust the hard lines a tad.
    Just a thought. Darn shame there aren't 70 hoses, but I'd bet there is a brake hose out there that would come close to working.
  7. mercgt73
  8. predfan2001
    The 70 Maverick uses a banjo bolt at the cylinder end. The Mustang hoses thread directly into the cylinder.
  9. mercgt73
    Ah, gotcha. (y)
  10. pace70'
    pace70' Member
    Plumas Lake California
    1970 Maverick =)
    I have a 70 as well and all I did was buy 71 lines and wheel cylinders!! works good, all I need to do now is make a little bracket to bolt the line back to the frame as the 70 brake line had the bracket built onto it. But that should be a easy fab.
  11. Dianne
    Dianne Member
    Nampa, ID
    We're doing the Mustang thing on this one, and seems like it will work fine I've been told. When he gets to that part, I should have pictures!
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    It's time for front disc brakes anyway. Forget '70 hoses.
  13. Dianne
    Dianne Member
    Nampa, ID
    Here is where it is and done with the brake line conversions. I never did a build page, but this is where most is right now. I don't do the mechanics, and paint and stuff I do. My Pinto wagon is close to paint!
    YOu can see the brake line conversion on here also...
  14. Dianne
    Dianne Member
    Nampa, ID
    I needed a clean pan :)
  15. CDL
    CDL Member
    I have a 70 that needs these hoses. I have looked around and this seems to be the easiest to do.
    Has anyone been able to verify if this works? 1971 Hoses and Wheel cylinders are widely available.
    Thx ahead of time
